Radiator problem, need some help ...
Old Apr 25, 2004 | 08:32 PM
Vinhtran17's Avatar
Default Radiator problem, need some help ...
I have a 95 ls with about 80,000 miles on it. i had just replaced the oem radiator with a new metal radiator. soon enough, i see that my upper hose is getting real plumpy ( or expanded or swelled). So a mechanic had told me that its just worn out and i need to get a new upper hose. so then i bought a new upper hose and had installed it. now its all good. but then i noticed that i am losing radiator fluid slowly from my resevoir. it gets nearly empty every 2 or 3 weeks. i always check in and around the engine bay to see any leaks around anywhere. no siteing of any leaks.checked the radiator cap, upper and lower hoses. etc. does anyone know what the problem is? thanks to all that had helped. keep up the good work.
Old Apr 25, 2004 | 09:33 PM
Stripped Honda's Avatar
99-0104
Default Re: Radiator problem, need some help ... (Vinhtran17)
your going to have to do a leakdown test to see if you have a blown headgasket
Old Apr 26, 2004 | 09:53 AM
Vinhtran17's Avatar
bump
Old Apr 26, 2004 | 10:55 AM
ebelp's Avatar
Default Re: (Vinhtran17)
Leave your car running in one place for a while and let the engine get hot. See if it starts to drip from anywhere.
Old Apr 26, 2004 | 11:27 AM
stasi's Avatar
Default Re: (ebelp)
Do you smell coolant burning off out of the exhaust?
You may have a leak somewhere. Double check all of your hoses. See if there's any residue around where the head meets the block. You're losing or burning coolant off somewhere.
Old Apr 26, 2004 | 11:46 AM
95Teggy's Avatar
make sure to put in antifreeze, if you put water in there, it will evaporate.
Tic55
Honda Civic (2001 - 2005)
16
Sep 1, 2018 12:13 AM
Dooley
Apr 15, 2006 06:55 PM
ecarfar
Dec 6, 2005 01:39 PM
94gsr_vtc
12
Jul 26, 2004 08:23 AM
Chip398193
Sep 10, 2001 01:12 PM
