PCV install?
shake it? my helms manual says that if you pinch the tube and it makes a clicking sound it means its working
how can i tell if it's good or not, i bought it new?
the valve should make noise. wheathers its new or not. If it dont its either defective or broken.
I'd say include it in the regular tune up. along with spark plugs, wires, rotor, cap, pcv valve etc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by misfit »</TD></TR><TR><TD CLASS="quote">he said shake it. lol... had to James.
Postcount +1
If you shake the PCV valve it should make a rattling sound. If it doesn't, then the little piece of plastic inside is too caked in oil (or just broken), in which case you can either replace it or try spraying it with carb cleaner.
I usually just spray mine with carb cleaner but you can replace it too...
</TD></TR></TABLE>Postcount +1
ah alright
i don't kno what's going on tho, i was listening to it and it clicks at idle and then when i squeeze the tube it stops? wtf, its supposed to be the opposite way
DC 2
Apr 14, 2004 11:30 PM
