Pulled ABS code
Old Apr 23, 2004 | 08:43 AM
FK00GSR's Avatar
Default Pulled ABS code
Ok i just pulled an ABS code and it gave me the following 2 codes:
15 RR Wheel sensor (open/short to body ground/short to power)
16 RR Wheel Sensor (electrical noise/intermittent interruption)
Does anybody have any idea how to fix this, do i need to replace the wheel sensor or is there another way to go about fixing it?
Old Apr 23, 2004 | 11:33 AM
JimBlake's Avatar
Default Re: Pulled ABS code (FK00GSR)
Follow the wiring from that sensor, look for an open, or a short, or a loose/flaky connection somewhere.
Old Apr 23, 2004 | 11:39 AM
FK00GSR's Avatar
Default Re: Pulled ABS code (JimBlake)
how far does the wire go and where does it go? Is there a wire diagram of it anywhere?
Old Apr 23, 2004 | 06:29 PM
FK00GSR's Avatar
anybody?
Old Apr 25, 2004 | 04:09 PM
JimBlake's Avatar
On my '95 the wiring harness goes across to the ABS computer, which is near the RR wheel well. But I know they changed the ABS system around a couple years after...
alexthegreat5
Honda CR-V & Element
Jul 30, 2018 05:19 AM
FasterScooter
Jan 21, 2013 06:57 AM
2gnarly
Mar 1, 2009 03:24 PM
ludee00
Nov 21, 2005 04:22 AM
JDM97R
Aug 13, 2004 10:31 AM
