how to check knock sensor?
Old Jun 27, 2004 | 11:44 AM
beanbag's Avatar
Default how to check knock sensor?
Is there a way that a KS can start to go bad, but not cause a CEL light? Coz I have a 97 gsr that knocks a little bit under load. It makes that tinkling marbles in a can sound, so I don't think it is a heatshield or something else. I thought if you have a KS it won't knock/ping?
Old Jul 3, 2004 | 08:57 PM
h22acrd's Avatar
Default Re: how to check knock sensor? (beanbag)
a knock sensor doesn't make it not ping, it just tells the ecu when your engine is pinging so it can adjust the fuel and timing to make it run richer. i don't think there's a way of checking a knock sensor without expensive equipment such as an oscilloscope.
maomaniarocks
May 4, 2007 09:33 PM
92ludeport
Jul 8, 2005 02:08 PM
NtgraTrboWanaB94
Mar 31, 2003 07:50 AM
DR. ON POINT
Dec 12, 2001 12:26 PM
