Droping the kar
Old Jun 26, 2004 | 10:48 PM
RedInTegRa6's Avatar
Default Droping the kar
If I drop my 95 integra 1 3/4 in. , do i need anything else except for the springs?
Old Jun 26, 2004 | 11:03 PM
GrafxDesignGuy's Avatar
Default Re: Droping the kar (RedInTegRa6)
struts if you really want the car to handle well...
camber kit if you want to save your tires.
Old Jun 27, 2004 | 12:03 AM
JFG Kevin's Avatar
Default Re: Droping the kar (GrafxDesignGuy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GrafxDesignGuy &raquo;</TD></TR><TR><TD CLASS="quote">struts if you really want the car to handle well...
camber kit if you want to save your tires.</TD></TR></TABLE>
exactly what you need....dont go cheap on suspension mod...that's my advice to you...i went through three set-up before i got smart about it..
Old Jun 27, 2004 | 01:30 AM
95TrboTeg's Avatar
Default Re: Droping the kar (aznstyler119)
yeah they are both right I got a cheap lowering kit, without new shocks with camber way off and it bounces and my tires were shot after 9000 miles. Id say get tein coilovers. (kinda expensive) But what I am gonna buy on my teg. Then go and get the camber adjusted and you will be set
Old Jun 27, 2004 | 04:39 AM
NightRiderS2K's Avatar
In-N-Out Burger
What is "droping" again?
j.k.
Anyways,
It is a misconception that camber causes uneven tire wear... AGREED it is caused by EXCESSIVE camber, although the real culprit is improper TOE settings.
You can be off 1-2 degrees with your camber, but with a proper alignment, your tires will wear evenly.
I only suggest a camber kit if you adjust the height level of your car at least more than once a year.
Some people do that...
Like me
NRg
Old Jun 27, 2004 | 08:58 AM
integraXTC's Avatar
if you drop 1.0F/1.4R do you need shocks and camber kit. And if so do you need it ASAP?
Old Jun 27, 2004 | 09:08 AM
G-bonic's Avatar
Hijacked
nice answer and plus be gud driver so u wont scrape the whole s*** out.....
Old Jun 27, 2004 | 04:27 PM
In-N-Out Burger
Default Re: Droping the kar (Stock_LS)
I advice you change your avatar before a mod sees it....
Old Jun 27, 2004 | 04:54 PM
lke2drvgsr's Avatar
stock shocks on lowered springs will blow the oem shocks, just lettin ya know.
camber kit isn't entirely necessary, just make sure your toe is within .08º
Old Jun 29, 2004 | 08:50 AM
yourmom25's Avatar
Default Re: Droping the kar (chitwn91rs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chitwn91rs &raquo;</TD></TR><TR><TD CLASS="quote">if you drop 1.0F/1.4R do you need shocks and camber kit. And if so do you need it ASAP?</TD></TR></TABLE>
first of all, with what springs, do you get that drop? that's a horrendous drop for the integra. your rear will be nicely tucked and the front will still look like a 4x4. please dont get those springs.
plus a drop like that will make your car very unbalanced. you might need a camber kit for the rears. eventually youll need new shocks. first thing anyone should do aftera drop is an alignment, from there you can see if you need a camber kit and how much your toe changed with the drop.
Old Jun 29, 2004 | 09:16 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Droping the kar (yourmom25)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yourmom25 &raquo;</TD></TR><TR><TD CLASS="quote">
plus a drop like that will make your car very unbalanced. you might need a camber kit for the rears. eventually youll need new shocks. first thing anyone should do aftera drop is an alignment, from there you can see if you need a camber kit and how much your toe changed with the drop.</TD></TR></TABLE>
What the hell? Are you sure you read his post right? He said 1" front and 1.4" rear, that's like one of the mildest drops you can get. Tucked? lol I'm lowered 3" and my rear tires are just barely inside the fenders.
Camber kit? no, totally not necessary for that mild of a drop.
Alignment, yes definitely, but wait about a week after installing the suspension.
Hell a drop that mild could probably be used on stock shocks w/o much trouble, but I would get new shocks anyway.
Next time read the post so you don't post a ton of misinformation.
Old Jun 29, 2004 | 10:58 AM
In-N-Out Burger
Default Re: Droping the kar (PatrickGSR94)
yourmom got pWned (sorry, had to say it).
illiterate *****
To stay on topic, after you install (elaborating on what patrick said) ie: any suspension change, height, new coil sleeves, etc,...let it settle first (about a week of driving) before you take it to an alignment shop.
NRg
Old Jun 29, 2004 | 11:24 AM
yourmom25's Avatar
I meant horrendous as in the front will be way higher than the rear. I was exaggerating when I said tucked. Integras are known to have a higher cut on the front fenders than the rears. A 1F/1.4R drop would only magnify that. I'm dropped on Eibach Prokit and it's nowhere near tucking but the front can fit 2 fingers and the rear can barely fit one.
Didn't mean to post wrong info, you just read it wrong. And I agree with what you said, but it's still better to look at the numbers when you get the alignment done to see if your camber is outside of the acceptable range. I've known of some cars where the camber was previously messed up and they didn't find out until after an alignment.
Old Jun 29, 2004 | 07:17 PM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yourmom25 &raquo;</TD></TR><TR><TD CLASS="quote">I meant horrendous as in the front will be way higher than the rear. I was exaggerating when I said tucked. Integras are known to have a higher cut on the front fenders than the rears. A 1F/1.4R drop would only magnify that. I'm dropped on Eibach Prokit and it's nowhere near tucking but the front can fit 2 fingers and the rear can barely fit one.
Didn't mean to post wrong info, you just read it wrong. And I agree with what you said, but it's still better to look at the numbers when you get the alignment done to see if your camber is outside of the acceptable range. I've known of some cars where the camber was previously messed up and they didn't find out until after an alignment.</TD></TR></TABLE>
With a drop as mild as that, there will be enough gap that any difference front to rear probably won't be noticeable. On my car, I had more fender gap in BACK before lowering. The H&R Sports I put on supposedly lowered 1.75F/1.5R, and with the Koni perches on the stock height all around, I had about 2 fingers gap in back, and less than 1 in front. That's why I took the rear perches down to the lowest level, to help even it out. The total drop on my car all around ended up being about 3".
Old Jul 3, 2004 | 03:53 PM
integraXTC's Avatar
these are eibach pros for the da9. And i messed up it is actually 1.4F/1.0R.
so might it be worth it now? also, i don't want to have a very harsh ride cuz city streets are bad.
Old Jul 4, 2004 | 10:12 AM
integraXTC's Avatar
bump
Old Jul 4, 2004 | 02:00 PM
hyperazn108's Avatar
you spelled car wrong..
Old Jul 4, 2004 | 06:48 PM
IntEGNYC's Avatar
Default Re: Droping the kar (hyperazn108)
wasnt K.A.R.R. the evil twin of K.I.T.T?
Hasselhoff rules Deutche land baby!
Old Jul 5, 2004 | 01:24 PM
Bad Robot's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
Next time read the post so you don't post a ton of misinformation. </TD></TR></TABLE> Yeah that mild a drop you might not need a kit at all...I did a mild drop on my 97 teg waited about 2 weeks, had the alignment done by a place out here called WEST COAST ALIGNMENT.. and found out that i can get by without a kit.. The alignment is the first thing you should do..
uses0ap
May 24, 2008 04:02 PM
mikelax125
Honda Civic (2001 - 2005)
20
Apr 3, 2007 02:44 PM
4ghatch
Suspension & Brakes
Mar 4, 2007 08:57 AM
gurlracer_camille
10
Feb 19, 2007 07:47 PM
JReed
38
Nov 12, 2003 11:54 AM
