LS Turbo Problem
Just broken into the turbo... when i rev it pass 4000RPM the check light comes on.... and with the check light on at idle the motor shuts off... i would have to turn off power and then restart it again... Also when i power on the fuel pump my fuel guage wont work... but when i let the fuel pump sit without no power the fuel guage work.... any experiences like this.....
How much boost you running? Do you have a missing link? Give us some more info.
It sounds like your overboostin on a stock map sensor, the honda ecu can only see up to 11 psi, after that it will throw a CEL, and shutoff, then all you have to do is restart.
I did this a couple times before I got my 3 bar map sensor.
[QUOTE=quikB18B]How much boost you running? Do you have a missing link? Give us some more info. It sounds like your overboostin on a stock map sensor, the honda ecu can only see up to 11 psi, after that it will throw a CEL, and shutoff, then all you have to do is restart.QUOTE]
It is completely stock bolt-on turbo GT30R using wastegate 6-7psi... No ECU or Tunning yet but just wondering what could it be Fuel problem or my setup is all F*%ck up because of something i did... i dont know
00 Si
Jul 5, 2001 01:38 PM
