VTEC not working
Old Jun 26, 2004 | 05:52 AM
INTEGDA6UK's Avatar
Default VTEC not working
I have just acquired a 92 DA6 (Jap Import) The car drives fine but the VTEC dosent kick in, where do I start to look?
Modified by INTEGDA6UK at 1:41 PM 6/26/2004
Old Jun 26, 2004 | 05:59 AM
IntegraLova's Avatar
Default Re: VTEC not working (INTEGDA6UK)
On ebay to get a diffrent car bc you obviously dont need to **** up a 2nd gen gsr if in fact thats what it is.
Old Jun 29, 2004 | 11:28 PM
integrarider's Avatar
Default Re: VTEC not working (IntegraLova)
dont import from the japinese
Old Jun 29, 2004 | 11:31 PM
lke2drvgsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraLova &raquo;</TD></TR><TR><TD CLASS="quote">On ebay to get a diffrent car bc you obviously dont need to **** up a 2nd gen gsr if in fact thats what it is.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integrarider &raquo;</TD></TR><TR><TD CLASS="quote">dont import from the japinese </TD></TR></TABLE>
stfu noobs.
check ur oil, if it's low on oil vtec won't engage, that's usually the cause.
Old Jun 30, 2004 | 07:10 PM
95 integra's Avatar
DA6? Dont know alot about JDM chassis codes or what came in them over there, but I do know that the 2nd gen gsr is a DB, and that the DAs in the US dont have vtec. Whats your redline at?
Old Jun 30, 2004 | 08:00 PM
Dc2 Powered's Avatar
my uncle had a 1993 acura integra gs-r and it was in superstreets first magazine they said it was 91 tho -_-... stupid superstreet.. also what lke2drvgsr is excitly right dont listen to dumbasses with dumbass responses hereo n honda-tech.. and trust me you'll get lots of them.. also what do you mean imported from japan? is it a RHD?
Old Jul 1, 2004 | 12:42 AM
INTEGDA6UK's Avatar
Default Re: (Speedin Type R)
Yes it's a RHD im in the UK
Old Jul 1, 2004 | 12:44 AM
INTEGDA6UK's Avatar
Default Re: VTEC not working (95 integra)
It redlines at 8400rpm
Old Jul 1, 2004 | 12:49 AM
t . b o z's Avatar
check your oil, if its low that will cause the problem. If the oil level is ok, check to see if your vtec solenoid is working, if not replace that, and if worse comes to worse...see if the vtec is wired to the ecu or if the car even has a vtec ecu =x
Old Jul 1, 2004 | 12:57 AM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">DA6? Dont know alot about JDM chassis codes or what came in them over there, but I do know that the 2nd gen gsr is a DB, and that the DAs in the US dont have vtec. Whats your redline at?</TD></TR></TABLE>
The DB chassis is a 94-01 4 door Integra, not a second gen. All the first and second gen's are DA's. The DA6 is the 90-93 2 door. He stated that he did import the car from Japan where some DA's came with B16A's.
Old Jul 1, 2004 | 07:06 AM
JiggyKooAndy's Avatar
make sure your letting the engine warm up as well before you start going at WOT...
Old Jul 1, 2004 | 07:38 AM
MAV3RiCK478's Avatar
Default Re: VTEC not working (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">
All the first and second gen's are DA's. The DA6 is the 90-93 2 door. </TD></TR></TABLE>
not this again, wrong. second gens 2drs in the us were DA9, 4drs were DB1 and gsrs were DB2.
and like everyone else said, check your oil level and make sure your car is warmed up. otherwise vtec will not engage.
Old Jul 1, 2004 | 11:16 AM
dashway's Avatar
Also check for codes...that might be sumn too...love g2s (XSI here)
Check out http://www.G2ic.com
Old Jul 1, 2004 | 11:44 AM
INTEGDA6UK's Avatar
Default Re: VTEC not working (dashway)
This is my model here
http://www.alljapanesecars.com...c=DA6
Old Jul 1, 2004 | 12:11 PM
92vx6's Avatar
oil most likely is the problem........
hotroddb8r
Nov 18, 2007 06:50 AM
skylude23
Mar 28, 2007 02:18 PM
95GSRDC2
May 23, 2006 05:46 PM
9000rpms
May 15, 2006 02:26 PM
fastludeh22
Jan 27, 2005 02:05 AM
