Very bad idle problem
Old Jun 27, 2004 | 04:24 PM
AMD-GSR's Avatar
Default Very bad idle problem
I just put Crower Stage 2's with crower valve springs and retainers and now it sounds like i have a hotrod but the only thing is it will not keep idle. it dies out. i know that im not getting vaccum pressure from somewhere i think. i messed with the timing but i dont know if that is it. i hope. if anyone can help me i would GREATLY apprecate it. Note: i did look at all my connections, grounds, timing, even tightend the head down more and its sputters bad. i tried a different ECU and changed plugs an wires man i mean everthing. does all crowers do this or what. i had the machine shop install that springs and retainers also.
Old Jun 27, 2004 | 05:01 PM
G1 TEGGY's Avatar
Default Re: Very bad idle problem (AMD-GSR)
did you remember to work in the new cams first?? You can't let them idle when you install them, you need to keep them at 2500 RPM for a bit to lubricate them. Hope they're alright
Old Jun 27, 2004 | 05:44 PM
AMD-GSR's Avatar
well when i turn on the car it sputters then it cuts off, so i really cant break them in yet.
Old Jun 27, 2004 | 05:54 PM
tommymoose's Avatar
Default Re: (AMD-GSR)
I have no idea at all, but from looking at the last two responses I would say start the car, and make sure you give it some gas so that you force it to warm up rather than let the car idle warm.
Old Jun 27, 2004 | 06:00 PM
milo's Avatar
Default Re: (tommymoose)
did you adjust the valves too?
Old Jun 27, 2004 | 06:35 PM
AMD-GSR's Avatar
yes no knocking or nothin
Old Jun 28, 2004 | 10:04 AM
AMD-GSR's Avatar
it will run but im not sure anymore if i might have bent a valve or not?
Old Jun 28, 2004 | 03:37 PM
AMD-GSR's Avatar
i am getting a compressior test done and i hope this will tell me if i got a bent valve or not.
Old Jun 30, 2004 | 07:46 AM
AMD-GSR's Avatar
Update! i did a compression test and they all came out around 100-110. i know GSR's are around 190 or somthing. does that mean im losing air somewhere in the head?
Old Jun 30, 2004 | 07:07 PM
95 integra's Avatar
Yes, you are losing compression somewhere. Since it happened when you put the cams in(from what I understand), Im going to say that you need to adjust the valves. If they arent adjusted properly its possible that they arent closing all the way, causing you to lose compression and idle like ***.
Old Jun 30, 2004 | 07:08 PM
95 integra's Avatar
Default Re: (95 integra)
Oh btw, are you 100% positive that you did the compression check properly? Generally when people get constant low readings across all 4 cylinders that means they didnt do something right. Like having the car at WOT or something.
Old Jun 30, 2004 | 07:18 PM
shermanyang's Avatar
my crower's on my turbo'd ls idled funny too and would almost stall the motor. yes it does sound like a hotrod motor...i loved it, and i loved the extra few horses it gave me. if you want the hot rodding noise to go away, you'll have to adjust and turn the idle up.
Old Jun 30, 2004 | 07:30 PM
Gfunk176's Avatar
Default Re: (shermanyang)
sound like you didn't do a valve adjustment after you put the new cams in.
Old Jun 30, 2004 | 09:31 PM
Sack Master's Avatar
Default Re: (Gfunk176)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shermanyang &raquo;</TD></TR><TR><TD CLASS="quote">my crower's on my turbo'd ls idled funny too and would almost stall the motor. yes it does sound like a hotrod motor...i loved it, and i loved the extra few horses it gave me. if you want the hot rodding noise to go away, you'll have to adjust and turn the idle up.</TD></TR></TABLE>
Your LS cams were probably a bit different than his gs-r cams, but thanks.
Sounds like your cam timing is off. But also as everyone said make sure your valve lash is set before you go for break in.
Old Jul 1, 2004 | 07:46 AM
AMD-GSR's Avatar
Default Re: (Sack Master)
Kool thanks much i want to do it myself.it sounds easy. Question? what tools would i need to adjust, or to look at them.? Yes i belive i did it right i took of the distribitor wires unscrewed the plugs starting at clyinder 1 installed the compressior, cut it over a couple times and got a reading. did it twice because it was so low.
Modified by AMD-GSR at 9:03 AM 7/1/2004
2.2Lude
Apr 14, 2010 10:51 AM
quick99gs-r
May 25, 2009 06:35 AM
egsi32
13
Jun 22, 2005 10:30 PM
h22a193
Dec 28, 2004 05:52 AM
B18C_EJ8
Jun 27, 2003 12:18 PM
