ls vtec
Old Jul 18, 2004 | 09:31 AM
elusive123's Avatar
Default ls vtec
i have a b18b (ls)block and a b18c (gsr)head and skunk 2 cam gears
!. what timing belt should i put on it the ls or the vtec
2. what head gasket should i use the ls or the vtec
3.do the dowel pins on the block have to be drilled out
Old Jul 18, 2004 | 10:03 AM
mademan2723's Avatar
Default Re: ls vtec (elusive123)
Top right hand corner Click Search
Old Jul 18, 2004 | 10:37 AM
riceball777's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elusive123 &raquo;</TD></TR><TR><TD CLASS="quote">i have a b18b (ls)block and a b18c (gsr)head and skunk 2 cam gears
3.do the dowel pins on the block have to be drilled out</TD></TR></TABLE>
you need ti use a ls non vtec head gasket
you need to match the timing belt with the vater pump. so if you use a ls timing belt y ou will need to use a 19tooth ls water pump and if u use a gsr/itr timing belt you will need to the the 22 tooth gsr/itr water pump
and about the dowels
you ca either take the head to a machine shop to have them machine the dowels on to the intake side of the head because the dowels are on the intake side of a ls block not on the exhaust side like a vtec block
or
you can just buy the golden eagle dowels which let you use them on the exhaust side with no machining required
Old Jul 18, 2004 | 10:46 AM
G
sh!t happens.
Default Re: ls vtec (riceball777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 &raquo;</TD></TR><TR><TD CLASS="quote">
or
you can just buy the golden eagle dowels which let you use them on the exhaust side with no machining required </TD></TR></TABLE>
he explianed it perfect there..... i think you have to make the head gasket holes bigger so the dowel pins will go through.. i heard that on one of these ls/vtec threads.
Old Jul 18, 2004 | 11:06 AM
elusive123's Avatar
the thing is i had a b20b swap with the vtec head on it and it has the dowels on the intake side of tat and i think the head might have been drilled but in that case i can just get the small dowels located on the exhaust side like u said, i have to check tat out.
is the ls gasket going to need any modifications or will i be ok with the size of the oil holes and everything.
i kinda figured that u had to match the belt and pump i just didn;'t know if there was a better of the two
thanks
da.nizzle
May 5, 2008 12:10 PM
boosted92hatch
May 29, 2006 08:44 AM
SL0WEGG
May 5, 2005 02:51 PM
JDMvtecDRAGSTA
Aug 1, 2002 05:19 PM
