4500 vtec????
Old Jul 16, 2004 | 11:55 AM
ferio 95's Avatar
Default 4500 vtec????
Ok i removed the secondaries off of my gsr and left the plate in as a spacer. It rode fine for a while and hauls all types of ***(and doesnt lose all that low end like all the e-geniuses say it does). Now the other day the CEL came on so i pulled over and tryed to run the numbers but nothing flashed and VTEC kicks in at 4500. Ive heard that vtec is posta be at 4500 or gsr's and the secondaries open at 5200 or visa versa could this be the problem?
Old Jul 16, 2004 | 12:01 PM
tegasaurus's Avatar
Default Re: 4500 vtec???? (ferio 95)
if you can't pull the code, its an ecu problem - if that was the case you wouldn't be able to rev past 3500rpm or so.... and in that case it makes me think you should BE able to check the codes... so go try again tiger
Old Jul 16, 2004 | 08:25 PM
ferio 95's Avatar
Default Re: 4500 vtec???? (tegasaurus)
still no luck and i doubt its a ecu malfunction. i have no clue on what the hell it could be. It might be tied into the sudden stroke of stupid **** happening such my pc not reading harddrives, counter strike getting hacked, etc.
Old Jul 16, 2004 | 08:57 PM
otakueric's Avatar
vtec is 4400
if ur car is running fine, and no codes come up
dont worry about it
but...i think a code should come up :\
try it again?
Old Jul 17, 2004 | 02:02 PM
ferio 95's Avatar
Default Re: (otakueric)
no there is a code, it stays on constant while the car is on. But when i try to see what the cel reads out it wont blink as if it doesnt have a cel issue
Old Jul 17, 2004 | 02:12 PM
dc2drifterx's Avatar
vtec 4400rpm
secondaries 5800 rpm
Old Jul 17, 2004 | 02:35 PM
ferio 95's Avatar
Default Re: (dc2drifterx)
ah i c, but that still doesnt help explain the cel
dougk1401
Dec 7, 2009 08:55 AM
iCONxEG21
12
Dec 8, 2007 03:53 PM
tuckin15s_8315
Sep 28, 2005 09:35 PM
B18C-Hatch
Aug 31, 2002 02:04 PM
