ls vtec question
Old Jul 15, 2004 | 08:39 PM
hondaluva's Avatar
Default ls vtec question
i know this is kinda of a noobie question but if i run a usdm b16 head on a ls block with stock internals, aem cai, itr header, skunk 2 stage 1 cams, skunk 2 cam gears, a p28 chipped or hondata s100, and greedy evo 2 exhaust as a daily driver how long will this motor last me and how reliable will it be. as long as i have a proper build done should this last me as long as a gsr. i'm not building a race motor just a quick daily driver if there are any changes i need to make it more reliable let me know. thanx for ur input in advance.
Old Jul 15, 2004 | 08:48 PM
allmotorteg_96's Avatar
Default Re: ls vtec question (hondaluva)
well mine lasted a year problem free everything in the head look fine when i took it off. The only reason i took it off was to start a new project.
Old Jul 15, 2004 | 08:52 PM
hondaluva's Avatar
Default Re: ls vtec question (allmotorteg_96)
thanx for the response what do u think of the set up
Old Jul 15, 2004 | 09:52 PM
i loved it and it pulls hard.
Old Jul 15, 2004 | 09:59 PM
Fook_me_honda's Avatar
I heard that to make it run reliable u have to drill oil tap lines for the vtec in the ls block, and/or block it up, but some guy from portland over here runs ls/vtec with 75 shot nos and he's been around for a bit so he's fine-
Old Jul 15, 2004 | 10:02 PM
hi mom's Avatar
Default Re: ls vtec question (Fook_me_honda)
Ive had mine for about 2000 miles.
hondata p72 stock internals and head except for cam gears, and I havent had any problem, just upgrade to gsr oil and water pump, and make sure you run a feed line to the head for oil, other then that, you should be gravey to giver up to 72000 rpm''s
Old Jul 15, 2004 | 10:12 PM
Default Re: ls vtec question (Mulldog)
i took mine to 8200
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mulldog &raquo;</TD></TR><TR><TD CLASS="quote">Ive had mine for about 2000 miles.
hondata p72 stock internals and head except for cam gears, and I havent had any problem, just upgrade to gsr oil and water pump, and make sure you run a feed line to the head for oil, other then that, you should be gravey to giver up to 72000 rpm''s</TD></TR></TABLE>
if u change out the oil and water pump u will need a vtec timing belt. I just used my ls oil and water pump with a ls timing belt.
Old Jul 15, 2004 | 10:14 PM
hi mom's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorteg_96 &raquo;</TD></TR><TR><TD CLASS="quote">i took mine to 8200
if u change out the oil and water pump u will need a vtec timing belt. I just used my ls oil and water pump with a ls timing belt.</TD></TR></TABLE>
haha 8200 on stock interanls?
BOOOOOOOOOOOOOOM.
and yes I forgot to mention that I got a B16 timing belt, GSR water and oil pump, aswell as ARP head bolts..
Old Jul 15, 2004 | 11:08 PM
Sack Master's Avatar
How did you get a b16 timing belt to fit? That had to have been mighty tight. Anyways, I've had my lsvtec in my car for 4 1/2 years and haven't had too many problems. I blew an oil line shortly after I built it but luckily only lost about 1/4 of a quart. Thats about the biggest problem. I drive my car every day and still runs like a champ(or maybe a chump I don't know).
Old Jul 16, 2004 | 12:22 AM
4DooRGiSzer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaluva &raquo;</TD></TR><TR><TD CLASS="quote">i know this is kinda of a noobie question but if i run a usdm b16 head on a ls block with stock internals, aem cai, itr header, skunk 2 stage 1 cams, skunk 2 cam gears, a p28 chipped or hondata s100, and greedy evo 2 exhaust as a daily driver how long will this motor last me and how reliable will it be. as long as i have a proper build done should this last me as long as a gsr. i'm not building a race motor just a quick daily driver if there are any changes i need to make it more reliable let me know. thanx for ur input in advance.</TD></TR></TABLE>
i think if you want VTEC, just spend the whole nine yards and buy yourself a whole new motor (AKA----B16, B18C1, B18C(JDM Type R), B18C5)! why spend the money on something that wont last 150,000 miles with just oil changes and spark plug changes?!?!?!?
Old Jul 16, 2004 | 07:41 AM
Default Re: ls vtec question (4DooRGiSzer)
yes 8200 on stock bottom end with a gsr head and gsr head bolts. no problems i had it for a year and took it out to start a new project.
if u dont belive that i have about 8 people on honda-tech that can vouch for me
Old Jul 16, 2004 | 01:23 PM
hondaluva's Avatar
are u just talk out the side of your head or have u had a bad experience with a ls vtec build. i understand that gsr are most likely more reliable but i'm using all stock internals except for the cams other than than the motor is still made with same old everlasting honda parts as a gsr
Old Jul 17, 2004 | 12:15 PM
hi mom's Avatar
Default Re: ls vtec question (Sack Master)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master &raquo;</TD></TR><TR><TD CLASS="quote">How did you get a b16 timing belt to fit? That had to have been mighty tight. Anyways, I've had my lsvtec in my car for 4 1/2 years and haven't had too many problems. I blew an oil line shortly after I built it but luckily only lost about 1/4 of a quart. Thats about the biggest problem. I drive my car every day and still runs like a champ(or maybe a chump I don't know). </TD></TR></TABLE>
haha I meant to type B18.
It was GSR timing belt, water pump, oil pump and full gasket set from Honda, haha my bad.
Old Jul 17, 2004 | 04:03 PM
you can use the b18 belt if u keep the water pump, oil pump from the ls
JDM00SI
Nov 1, 2005 04:50 PM
lube
May 12, 2002 07:35 PM
LS-T
Oct 31, 2001 09:38 AM
LS-T
Oct 30, 2001 03:57 PM
