LS/Vtecs and Strokers....
Old Jul 16, 2004 | 11:53 AM
spoonfed95's Avatar
Default LS/Vtecs and Strokers....
I keep reading post about how LS/Vtec's and stroker engine are a bad idea. Peoples reason to this is they both have a bad R/S ratio. I ran across this article from Turbo magazine, http://www.turbomagazine.com/tech/0112tur_stroker. I see that a stock GSR has a R/s ratio of 1.58, I think this is correct. In this article they talk about Long rod's VS. Short rod's. they built a B18A with a 25MM deck extension, and used Crowers 95MM crank. With the longer rod not only did they make a stroker but it has a R/S ratio of 1.63. Thats better then a stock GSR. I am considering building this same engine for my car. Anyone with some thoughts about this?
Old Jul 16, 2004 | 12:29 PM
spoonfed95's Avatar
Default Re: LS/Vtecs and Strokers.... (spoonfed95)
Anyone?
Old Jul 16, 2004 | 03:23 PM
kNOwLedGeDA9
Guest
Posts: n/a
Alot goes into building a stroker engine with a deck plate (deck extension). It will require quite a bit of testing for clearances and claying the engine. A friend of mine had an LS/VTEC bored to 85mm with a custom crankshaft made by Jake's Racing. Lets say the motor was about a 2.4L and had a 3" deck plate. its not a motor to be built by an amateur, as it requires alot of maintainance and block reinforcement. More than likely you will need a closed deck setup like the Dart block.
Old Jul 19, 2004 | 08:43 AM
spoonfed95's Avatar
Default Re: LS/Vtecs and Strokers.... (kNOwLedGeDA9)
Yeah I was looking into Darts B20 Tall deck block for this. 3" Extension is a bit much I think. I am going to extend it only 25MM.
Old Jul 19, 2004 | 08:52 AM
FastAllmotorLsVtec
Guest
Posts: n/a
how do you measure rs ratio?
killerB16A
24
Mar 10, 2009 02:33 PM
Mfoehrkolb
Nov 21, 2007 05:37 PM
DCtito
Oct 11, 2006 05:47 AM
B18
Feb 13, 2002 11:59 PM
