need help quick
Old Jul 17, 2004 | 12:11 PM
94civicx's Avatar
New User
Default need help quick
I went out this weekend to service the car, 90k miles, and was in the process of changing out the fuel filter. The bottom bolt of the fuel filter was so tight I took
about 30 minutes to try and get it off. I sprayed wd40 and everything, Now my problem is, since I cranked on the fuel filter so much, the fuel line leading to the
bottom got all twisted and cracked. How much work is this to replace.
Old Jul 17, 2004 | 02:25 PM
94civicx's Avatar
New User
Default Re: need help quick (94civicx)
no one
Old Jul 17, 2004 | 05:55 PM
Dogginator's Avatar
Daisy... Daisy...
Ouch.
That won't be easy if you fix it correctly. If you have a 94-01, you need p/n 17700-ST7-930 (confirm this before ordering). It runs from the fuel pump (in the tank) to the filter. The cost is about $55.
Your second option is to go to a parts store and buy a fitting to fit the filter, a piece of rubber hose, and some hose clamps.
Good luck!
92blackg2
Feb 28, 2005 04:44 PM
REVOUTHIGH
Jul 6, 2004 11:32 AM
turboxsi
Jan 16, 2004 07:50 PM
CivilizedCiv
Aug 22, 2002 08:22 AM
AK94GSR
Aug 7, 2002 08:02 PM
