Problems adjusting headlights
Old Jul 16, 2004 | 07:21 PM
xstalkrx's Avatar
Default Problems adjusting headlights
First I read this article on headlight adjustment:
http://www.team-integra.net/se...D=388
ok i read the headlight article...and I loosened the bolts that it says to loosen in order to adjust vertically and horizonatally. My dad and I BOTH looked at this, we loosened the bolts, but the only thing that actually will move the headlight vertically or horizonatally is your hand. Simply loosing and tightening the bolts in the article DOES NOTHING for me. We have to adjust manually by hand and then tighten down.
Furthermore, the driver side doesnt seem to want to move any more to the left. The driver side assembly is pointed way too far in and is causing all kinds of mess for me at night. I dont really want to take it to a shop cuz I would feel like a dumbass. But right now, we just cant seem to figure it out.
Old Jul 16, 2004 | 08:09 PM
xstalkrx's Avatar
Default Re: Problems adjusting headlights (xstalkrx)
is there something im missing? anyone with a helms manual might be able to help me out here? Thanks.
Old Jul 16, 2004 | 08:50 PM
R.S.'s Avatar
well u need to loosen those bolts and move with you hand, the bolts them selfs don't move the head light. that is for just moving the headlight assembly around.
and for the vertical and horizontal adj, use a philips head screw driver and turn the gear type thing, it's located on the head light assembly, where those yellow circles are in that pic.
Old Jul 16, 2004 | 09:01 PM
xstalkrx's Avatar
we used a screwdriver but when you tighten and loosen it, it doesnt adjust the headlight.
Old Jul 16, 2004 | 09:08 PM
xstalkrx's Avatar
Default Re: Problems adjusting headlights (R-Spec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R-Spec &raquo;</TD></TR><TR><TD CLASS="quote">well u need to loosen those bolts and move with you hand, the bolts them selfs don't move the head light. that is for just moving the headlight assembly around.
and for the vertical and horizontal adj, use a philips head screw driver and turn the gear type thing, it's located on the head light assembly, where those yellow circles are in that pic.</TD></TR></TABLE>
i dont understand. you say the bolts themselves dont move the headlight assembly around but then you said that for vertical and horizontal adjustment to use a screwdriver and turn the "gear type thing". That gear type thing is a bolt.
Old Jul 17, 2004 | 07:36 AM
R.S.'s Avatar
oh i meant the bolts that hold the head light assembly onto the car, u can loosen those and move the whole headlight...
did you face the car to a wall at night and put the headlights on and then adjust?
Old Jul 17, 2004 | 07:47 AM
xstalkrx's Avatar
yes, we put the headlights on a wall. It seems that the right assembly is near perfect.
All adjustments that we have made have been manual though, loosening and tightening the adjustment bolts arent moving it anywhere. What is going on here.
Old Jul 17, 2004 | 09:34 AM
R.S.'s Avatar
maybe it's busted
Old Jul 17, 2004 | 10:03 AM
xstalkrx's Avatar
well the brackets are there and are intact
Old Jul 17, 2004 | 11:29 AM
dc2drifterx's Avatar
You don't need to loosen up the mount bolts at all. All the adjustments are in the loght itself. Even your manual that came with your Integra tells you how to do it.
Old Jul 19, 2004 | 09:03 PM
ILuvJDMITR's Avatar
well i dont even have the teg manual, can we clue me in too? what does the hole in the rad support adjust? low or high beam? and which direction is up? and does the lower adjuster change the other bulb? if so, which? it seems both bulbs tend to move when i adjust either one
Knightrider03m
Aug 19, 2012 09:15 PM
badger10-2
Honda Motorcycles
Feb 22, 2007 01:50 AM
aych2h
11
Jan 17, 2007 11:47 AM
Paprika
15
Jan 4, 2005 06:00 PM
smkngsr
Apr 8, 2002 08:12 PM
