Engine knock B18c1
Old Jan 27, 2012 | 01:54 PM
Ryan96GSR's Avatar
Default Engine knock B18c1
Just the other night I was heading home from work and noticed a dreaded knock coming from my engine.
The noise is most prominent between 1700rpm-2200rpm. Here was no major symptoms leading up to this point. My belt would squeal on start up when cold. The car has 212,000km.
The car is going into the shop next week but I thought id come to the Honda experts first to see if any of you might have a idea of what to look for.
I uploaded a video to give you an idea of what I'm dealing with. Any feedback would be appeciated. Thanks
http://www.youtube.com/watch?v=whHY0f3f2Nw
Old Jan 27, 2012 | 02:03 PM
kingofbattle909's Avatar
Default Re: Engine knock B18c1
=/ turn it off.
Old Jan 27, 2012 | 02:24 PM
Whiterice-gsr's Avatar
sounds like a spun bearing, sorry to say but thats a major fix, on the plus side ive known of hondas mostly h22 that will knock forever withut letting go. how capable are you at working on your car?
Old Jan 27, 2012 | 02:46 PM
Ryan96GSR's Avatar
I had a feeling it might be a main bearing.
I'm what you would call a hobbyist do it your self-er. Motor work is over my head, and I'm not willing to risk damaging the engine further to try and save my self money. Anyways now I'm rambling.
Thanks for your advice.
Old Jan 27, 2012 | 03:48 PM
actually its probably a rod bearing, if u want u can drop the pan and see if maybe u broke a rod bolt, if the crank is out of round it will probably cost more to fix than it would to replace considering your taking it in to be fixed. labour + machine shop u might as well just buy a new one. the more u drive it the more you will hurt the crank. if it were mine i would replace all the rod bearings and use arp studs and hope the crank isnt screwed. maybe just get your mechanic to confirm it is indeed a rod bearing and try replacing it it wont cost much to try that and if it goes again then u know the crank is toast and u can decide from there, tell me do u beat on your car? do u race it or is it just a DD.
Old Jan 27, 2012 | 03:57 PM
sebTeggy's Avatar
drain the oil, is there lots of metal shavings?
Is your oil low? Hondas are meant to rev hard, you most likely ran low on oil
Old Jan 27, 2012 | 04:14 PM
Ryan96GSR's Avatar
Good to know, thanks.
It's used as a daily driver. I rev it up now and then. Recently I've been keeping the revs and speed down to save the rest of my suspension and steering components lol.
Old Jan 27, 2012 | 04:18 PM
Ryan96GSR's Avatar
Thanks for your concern, but No the oil level when the video was taken was just above half way on the dipstick.
I've owned the car since 163k. It had a bad oil pan when i bought it and I had to add oil every day for the first week before I replaced it.
I'm very conscious of all of my fluid levels.
Old Jan 28, 2012 | 12:40 AM
el crapitan's Avatar
if the crank didn't get damaged (unlikely), you could pull the pan and get at the rod bearings from underneath
Old Jan 28, 2012 | 05:34 AM
^^^ thats what i would do before i took it in. i only go to mechanics for safety, tire changes and alignment.
Old Feb 5, 2012 | 01:32 PM
Ryan96GSR's Avatar
Just thought I'd update this.
I had the car in today and the engine is fine. He catalytic converter blew up and bits and pieces were rattling about in the casing.
Old Feb 5, 2012 | 01:44 PM
wow. just goes to showhow hard it is too diagnose by a pic or video i woulda sworn that was a rod bearing lol.
Old Feb 5, 2012 | 02:09 PM
bnetkillzone's Avatar
Whoa! Really?! Never woulda thought of that. Your engine is fine, thats good.
Old Feb 5, 2012 | 02:52 PM
sebTeggy's Avatar
Thats why I said drain the oil and check for shavings.
You are one lucky dog! Id be jumpin for joy.....
Old Feb 5, 2012 | 03:05 PM
^^^x2
Old Feb 5, 2012 | 07:38 PM
Ryan96GSR's Avatar
Lol exactly. It's one of those things you need to get in there and see for your self.
Old Feb 5, 2012 | 07:47 PM
Ryan96GSR's Avatar
Very much so. It's odd since I had replaced the cat in October when I had emission test done. For it to blow up in 4 months is unusual.
Old Feb 5, 2012 | 07:48 PM
Ryan96GSR's Avatar
Believe me I am.
My next step was to drain the oil. I took some advice from a co-worker to check the exhaust first, luckily for me is was easily apparent once the car was in the air.
Old Feb 5, 2012 | 08:08 PM
DirtyDA9's Avatar
Yea I wouldn't have said rod bearing, as it doesn't constantly do it or go with rpms. It just kinda rattled at a certain rpm.
I am by no means saying I would have guessed the cat. But definately didn't seem like a thrown bearing.
Old Feb 7, 2012 | 04:34 PM
vito352's Avatar
ya, ive heard many of knocks and hearing the vid, i could understand how its mistaken for a knock, but really, it didnt seem to sound like a knock to me. glad ur gsr isnt toast. lol
Old Feb 7, 2012 | 09:01 PM
Solster's Avatar
if you got the cat from a shop most will warrenty them for the first year so i would take it back.
Old Feb 7, 2012 | 09:15 PM
raverx3m's Avatar
i was gonna go for the rear exhaust bracket. mine broke twice and was making same exact noise at same rpm
Old Feb 13, 2012 | 12:11 AM
Ryan96GSR's Avatar
Listening to it now, it seems a lot more apparent that is was exhaust related.
I was pretty much hoping for the best, but was prepared for the worst lol.
It still needs some TLC to get it where I want it to be, but it's getting there.
Old Feb 13, 2012 | 12:17 AM
Ryan96GSR's Avatar
I've already sorted it out the warranty details with the business that I originally purchased it from. thanks for the tip though.
I did have the part installed through a garage, but I bought the parts my self through another source to save cash.
Old Feb 13, 2012 | 12:18 AM
Ryan96GSR's Avatar
From the looks of it, my rear pipe assembly is in fragile condition and will likely be the next thing to go.
I may look into a cat back system in the future. I just hate loud exhausts, so It would be hard to commit to any brand.
