obx lsd question
Old Jan 23, 2012 | 10:26 AM
boosted_db8's Avatar
Default obx lsd question
hey guys this is my time on this forum so im new to this. i have a tranny im building and im using a ls case, gsr 1st-4th gears, ls 5th and gsr reverse.(the ls is missing reverse) im lookin into buying a used obx lsd and the kid says it fits b16 and ls trannies so my question is will this lsd work with my setup? some help will be appreciated thanx guys.
Old Jan 23, 2012 | 12:28 PM
95 integra's Avatar
Default Re: obx lsd question
As I recall it has to do with the size/# of bolts for the final drive.
Old Jan 23, 2012 | 12:40 PM
Whiterice-gsr's Avatar
i just ordered an obx helical lsd and im not seeing anything in the description that says its for any specific tranny. im building an ls tranny for the longer gearing third through 5th, hmmmm now you've got me worried, i'll do some research and see what i find. if anyone knows for sure that the bolt patterns are different on the final drive from gsr to ls please say so.
Old Jan 23, 2012 | 12:46 PM
ok so after another look the gsr and type R are different than the ls. luckily i ordered the right one for the ls. so you will need to use the ls final drive if you want to use that specific lsd unit.
Old Jan 23, 2012 | 12:48 PM
the gsr type r one takes 10 bolts and the ls takes 12 thats the difference.
Old Jan 23, 2012 | 04:11 PM
thanx guys this was the most helpful forum i've used. the responses were very quick too!
Old Jan 24, 2012 | 04:19 AM
thenoxus1's Avatar
Don't buy OBX. Take it from someone who sells parts for a living. They are very much a you get what you pay for brand. They have a fairly high failure rate, and I generally try to steer people away from them. Look at Quaife LSD's for something that will hold up and not shred your system.
Old Jan 24, 2012 | 04:30 AM
Tight-R's Avatar
There's a ton of ITR LSD's FS (not sure if it would work?) or snag a B16 trans with an LSD. That would be a winning combo for an ls car, unless you're turbo-ing it.
Old Jan 24, 2012 | 07:48 AM
B20ztek's Avatar
X2. I would never use an OBX part for anything important especially my transmission
Old Jan 24, 2012 | 07:52 AM
95 integra's Avatar
There are tons of reviews on the OBX unit. I would give an opinion, but I havent paid much attention to them in a few years, so they could have "improved" their design and/or building process now. However, it is true that the Quaife's are better and stronger....however, it is at a cost. I think I saw a new Quaife on ebay for about $600 though, which would be well worth the extra money.
Old Jan 24, 2012 | 12:40 PM
especially since its only 200 more than obx, i intstalled 2 of them so far without issue but neither car is making more than 300 hp, ill do some more research on the obx unit and post what i find, maybe i'll be sending mine back.
Old Jan 25, 2012 | 10:32 PM
My friend bought a newer obx LSD used and just took it apart greased and retorqued everything. He did over 40 dyno pulls on it at about 800whp and its still good till this day.
Old Jan 26, 2012 | 03:27 PM
thenoxus1's Avatar
Do as you please. But when it breaks, don't come crying to us for help. Just remember, I sell these things for a living, and have nothing invested in you picking one over the other. I'd rather save a month and have a few hundred buck more quaife etc then an OBX with known issues. Good luck op.
Old Jan 26, 2012 | 03:38 PM
so im sending back the obx i ordered, i didnt do enough research, im not putting that thing in my tranny, th company i ordered my carbon synchros from (synchrotech) is making lsd's for the teg and they specialize in honda only they look to be a quality part and are about 685 which more than an obx but not 1000 bucks like the quaife. has anyone got any input on the synchrotech lsd, i know there synchros are kick ***.
Old Jan 26, 2012 | 03:41 PM
quaife = 1000, sychrotech = 685, obx = 400,
Old Jan 26, 2012 | 03:49 PM
doood's Avatar
been there done that
pretty sure the lsd synchrotech sells is a rebranded mfactory. mfactory is still good though.
Old Jan 26, 2012 | 03:57 PM
i just emailed them. thanks,
Old Jan 26, 2012 | 04:56 PM
thenoxus1's Avatar
mfactory is decent. Quaife is not 1k..we retail them around 700. So if someone is asking 1k, it's a ripoff.
Old Jan 26, 2012 | 05:02 PM
racebum's Avatar
mfactory is excellent, those diffs have taken serious abuse and lived to tell about it
personally i would use a used jdm itr diff before an obx. if i remember right the problem with obx is with clearances. some are good, some aren't. there are videos on youtube and an article that was written where the install was done. i can't remember what the exact problem with the obx diff was, just remember they recommended blueprinting the clearances before install
Old Jan 26, 2012 | 05:06 PM
skyhighvtec's Avatar
anyone know if the LSD in a JDM B16a is the same LSD thats in an ITR tranny?
Old Jan 26, 2012 | 05:10 PM
doood's Avatar
good reading: http://patuned.com/forum/showthread....ghlight=quaife
Old Jan 26, 2012 | 05:13 PM
the reason i dont buy a jdm one is beacause im building a ls tranny for the longer gearing and they never made an oem one for the ls tranny, just gsr and type r, theres more bolts in the ls diff 12 opposed to 10 on the type r and gsr. im gonna give the synchrotech one a go just because they are wonderful ppl to deal with.
Old Jan 26, 2012 | 05:25 PM
Originally Posted by doood
that was good reading im so happy the op started this thread before i got mine so i cna send it right back, thanks
Old Jan 26, 2012 | 10:46 PM
Crazy_SI_T's Avatar
i too picked up a used obx lsd when i bought a box of tranny parts. (secret treasures) only paid 20$.
Dont wanna take this thread away from you but when i tip the lsd upside down back and forth i hear a sliding noise? normal? ill be replacing the washers as i can spot a hair line crack just curious on any ideas before i start diggin
Old Jan 26, 2012 | 10:57 PM
doood's Avatar
take it apart. probably trash inside.
