LS VTEC QUESTION???
Old Jan 18, 2012 | 03:57 PM
edgecpt09's Avatar
Default LS VTEC QUESTION???
I am building an Ls Vtec with the following
Machine bore and beck block to 81.5mm
ITR 81.5mm NPR Pistons, pins, and rings
King Main Bearings
King Rod Bearings
Ls rods?
ARP Rod bolts and studs
HMO B16a Head
Supertech dual valve springs and oem itr Retainers
ITR cams
Aem Adj Cam Gears
ITR Water Pump
ITR Oil pump
Full Race Vtec kit
B16 IM
Ls Throttle Body
Ls Injectors
P28 Chipped Icu
95' LS Teg
Question is Im really just trying to make a reliable Ls Vtec with a budget for a daily driver no track use. Should I shotpeen the rods? Thanks guys just thought I would let you all know what ive done so far. New to Honda tech so forgive me if im in the wrong forum.
Old Jan 18, 2012 | 04:15 PM
TheRealTegger's Avatar
Default Re: LS VTEC QUESTION???
And you're going through all that trouble and expense?
If you want a reliable daily-driver, just leave the engine stock. No stock Honda requires shot-peened rods.
Old Jan 18, 2012 | 04:25 PM
DirtyDA9's Avatar
Yes shot-peen them, don't forget vtec oil/water pumps and timing belt.
I'm building a fully forged internal LSVTEC, and it's gonna be my daily, so don't worry about the above comment.
Old Jan 18, 2012 | 05:43 PM
edgecpt09's Avatar
Perfect Will do!
ieatrice
Jun 4, 2008 08:12 AM
ieatrice
Apr 26, 2008 08:53 AM
peanuts8888
Oct 12, 2006 06:55 PM
peanuts8888
13
May 16, 2006 01:29 PM
hatchdrvr
Aug 8, 2003 12:51 PM
