which motor
Old Jan 18, 2012 | 01:49 PM
brad22486's Avatar
Default which motor
my dad has a 96 ls integra shop said its bad what motor do i buy to put in cant i just get 94 95 ls and swap intake n stuff over. any help is appreciated thanks
Old Jan 18, 2012 | 02:14 PM
DirtyDA9's Avatar
Default Re: which motor
You can put any B series in it, you would just need to swap over the wiring harness and get another ECU or adapter harness.
Old Jan 18, 2012 | 03:12 PM
doood's Avatar
been there done that
the easiest drop in swap would be another 96-99 b18b1
Old Jan 18, 2012 | 03:25 PM
shogun88's Avatar
That is true you can put any B series motor you can get your hands on in your integra but i think it all just comes down to what you want and kind of power you want to put down.
Old Jan 18, 2012 | 05:44 PM
pghz_last_don91's Avatar
Dont need to switch wiring harness or ECU.. Swap the intake mani, injectors and the oil pump and alternator.... 96+ has a sensor on the oil pump and the 94-95 doesnt.
Old Jan 18, 2012 | 05:52 PM
DirtyDA9's Avatar
Yea because an OBDO engine will work perfectly in an OBD2 car, come on dude, talkin out your ***. You forgot to mention distributor.
Old Jan 18, 2012 | 05:57 PM
talkin out my ***??? i have a 95 motor in my car.. and its a 99... yeah i 4got the distributor.. so b4 u go running your mouth know wat your talkin about..
Old Jan 18, 2012 | 05:58 PM
and if you know so much the motor is a OBD1 NOT 0
Old Jan 18, 2012 | 06:14 PM
DirtyDA9's Avatar
You obviosly didn't even read my original post, I'm talking about ANY b-series, that's why I said he would have to switch the wiring harness and ecu or get an adapter harness for the ecu. Glad to see you are another idiot that talks before he reads.
Old Jan 18, 2012 | 07:15 PM
el crapitan's Avatar
could drop a b20 in. won't need to transfer anything but the manifolds. a b20b can be had for pretty much the same cost as an LS. b20z, little more
Old Jan 18, 2012 | 07:26 PM
brad22486's Avatar
ok so a b20 out of a 96 to 99 crv just change the manifold
Old Jan 18, 2012 | 07:29 PM
brad22486's Avatar
on hmotorsonline they have a 96 to 98 crv long block for 599 plus shipping and handeling. with that i can keep everything the same except the intake manifold and im good to go?
Old Jan 18, 2012 | 07:39 PM
intake and exhaust manifolds
be sure to ask the specification of the motor. ie, b20b, b20z, jdm, or usdm. knock sensor, or no knock sensor
Old Jan 19, 2012 | 03:46 AM
brad22486's Avatar
http://www.hmotorsonline.com/shop/sc...age&item=30028
this is the one im looking at
Old Jan 19, 2012 | 03:54 AM
brad22486's Avatar
my dads sayin he wants a b18 so i guess ima have to buy ls
Old Jan 19, 2012 | 06:02 AM
hold on though. before jumping the gun, what exactly did the shop say was wrong with the motor?
Old Jan 19, 2012 | 07:32 AM
brad22486's Avatar
said that it was leaking fuel out of the head or some **** like and it had gotten hot and warped the head and since the head gasket honda uses that he cant mil the head.
Old Jan 19, 2012 | 08:21 AM
wakajdm8732's Avatar
If you do happen to get one from HMO, when your ordering it you should be talking to Steve. Just tell him what car it's going in to and he'll take care of it.
Old Jan 19, 2012 | 09:30 AM
doood's Avatar
sounds like a bunch of bullshit. get a second opinion. might be an easy cheap fix.
Old Jan 19, 2012 | 10:49 AM
DirtyDA9's Avatar
^^^ yup, that's all a load of crap that guy fed you and your dad.
Old Jan 19, 2012 | 11:30 AM
fcm's Avatar
fcm
Old Fart
"it was leaking fuel out of the head" Now that is a new one, never heard that one before.
I agree, although anything is possible, I would look for another opinion.
Question, did the shop pull the head, I was wondering how they knew the head was warped? 94
Old Jan 19, 2012 | 11:58 AM
DirtyDA9's Avatar
Exactly what I was thinking ^^. A head doesn't leak fuel lol. And the head can easily be resurfaced, they lied to you about that.
Old Jan 19, 2012 | 03:03 PM
brad22486's Avatar
yea i figured but i drove it home from the shop and it was running like **** no power and transmission was shifting high and the motor had no power i was lucky i got to 60 on the highway. and when i would full throttle it it would fall on its face and slow down but if my dad gets another motor i get his old one for doing the swap. and having an extra one laying around wont hurt. might not b bad for lsvtec turbo build or something
Cnorton1112
Oct 15, 2015 02:30 AM
twizted-myatt
51
May 29, 2011 07:36 AM
D15Bbigred
Jan 23, 2009 07:49 AM
supermotothud
Jan 22, 2009 09:17 AM
ramthis324
Apr 4, 2008 03:00 PM
