LSV problems, please help
Old Jan 9, 2012 | 10:15 AM
Boosted96gsr's Avatar
Icon2 LSV problems, please help
Hey guys so the other day I started my car and for some reason I decided to pull off the spark plug wires one by one, after the third spark plug the car shut off and now it wont start, I already tried checked the fuses and changed the ignition coil and still won't start, so i tried a different dizzy that worked and it won't start idk what to do any more please help,bob and the car is getting spark and fuel so.... Idk
Old Jan 9, 2012 | 10:18 AM
Dc4LsTeG's Avatar
EK9
Default Re: LSV problems, please help
Lol..were you trying to make your car sound like a Subaru?
Old Jan 9, 2012 | 11:17 AM
el crapitan's Avatar
recheck the firing order
Old Jan 9, 2012 | 11:20 AM
Dc4LsTeG's Avatar
EK9
Take a look at your spark plugs
Old Jan 9, 2012 | 11:57 AM
DirtyDA9's Avatar
Why were you disconnecting the wires one by one knowing that by the third it was gonna stall. Did you think a car can run on one cylinder? lol Just kiddin. How do you know you have spark? Did you check for spark at ALL 4 cylinders? White/blueish arc=strong spark, orange/yellow arc=weak spark.
I doubt messing with dist. wires would cause no fuel/air/compression, so obvioulsy it's something in the ignition, so did you varify spark at each plug?
Old Jan 9, 2012 | 12:16 PM
Integra4lyfe069's Avatar
??? were u that bored when u started ur car u decided to pull spark plugs wires??
Old Jan 9, 2012 | 07:54 PM
idk what the hell i was doing but i used a screw driver and checked the spark on all the cylinders, and i also cleaned the spark plugs. should i buy new ones??? it sounds like it wants to turn on but idk what else to do
Old Jan 9, 2012 | 08:04 PM
B20ztek's Avatar
guarantee your firing order is wrong..check that as other have stated and go from there
anht
13
May 1, 2010 11:57 AM
Civic Hybrid
10
Aug 17, 2008 09:35 AM
e jay one
Mar 4, 2006 06:02 PM
QTKEG6
Jun 23, 2002 10:14 PM
