Wrong coolant
Old Jan 12, 2012 | 07:28 PM
Da_1991's Avatar
Default Wrong coolant
I did not realize I added dex-cool coolant (red/orange) but only into my reservoir tank. Been driving with it for a couple of days. Should I do a whole flush or would be it be fine to just dump the reservoir tank out and get some green?
Old Jan 12, 2012 | 07:42 PM
Hidenplanvew's Avatar
Default Re: Wrong coolant
lol... Ya I would flush the whole system... How can you not telll the diffrence between orange and green?
Old Jan 12, 2012 | 07:43 PM
Wrona's Avatar
i would flush out the system with distilled water and put new coolant in who knows could be also good for the motor to have fresh coolant
Best coolant to use on a honda is the HOnda OEM Coolant
Old Jan 12, 2012 | 07:54 PM
el crapitan's Avatar
dumping the res tank won't do anything, as it should have cycled through the system. they're both ethylene glycol based. tbh, 1/2 a liter of dex cool isn't going to cause a catastrophe. if it were mine, i wouldn't bother
Old Jan 12, 2012 | 07:58 PM
Dex is known for causing water pump failure... I wouldnt want that junk in my motor.. Even my truck that came from the factory with dex I did a full flush and switched to green..
Old Jan 12, 2012 | 08:20 PM
^^this is true. but 1/2 a liter isn't going to cause any issues. personally, i don't think it's worth the trouble. unless the coolant in there is already spent
Old Jan 12, 2012 | 08:24 PM
Jeffaj20's Avatar
Just flush it and have no worries
Old Jan 12, 2012 | 08:32 PM
you guys realize that to properly flush the system and get all of it out, you'd need to drain the block as well, right? just dumping what's in the rad is only going to drain about half the entire capacity. and getting at that block drain is a pain.
Flipnotize21
Honda Civic (2006 - 2015)
Jan 19, 2007 07:31 AM
benmasters
May 25, 2003 12:47 PM
T_Rex
Nov 9, 2002 06:21 PM
LillDragun
Oct 25, 2002 07:44 PM
itr501
Jan 29, 2002 05:40 PM
