no vtec
Old Jan 22, 2012 | 11:12 AM
ari integra's Avatar
Icon2 no vtec
hey peeps.. i have a 91 integra it had in a b16a2... i am not getting any vtec... neither hear nor feeel it.... not sure what the problem might be...theres a slight leaking under where the solenoid is.... might that be the problem im not sure.... can somone help please
Default Re: no vtec
has**
Old Jan 22, 2012 | 11:17 AM
DirtyDA9's Avatar
Default Re: no vtec
Not enough oil pressure maybe. Check engine light on? Check your codes.
DirtyDA9's Avatar
Default Re: no vtec
Actually, did you swap the ECU?
Old Jan 22, 2012 | 11:19 AM
1994turbocivic's Avatar
Default Re: no vtec
fix leak. c what happens... vtec solenoids need to read certain oil pressure (i think 70psi?) to activate
Old Jan 22, 2012 | 11:26 AM
Default Re: no vtec
well ill try to get the leak fixed.... an no theres no engine check light on
Old Jan 22, 2012 | 11:32 AM
Default Re: no vtec
im not sure if the ecu was swapped i just got the car.... but the thing is the vtec works somtimes... not all the time.. when it works it revs to about 8300rpm an when the doesnt work it revs to 7000 rpm
Old Jan 22, 2012 | 11:47 AM
DirtyDA9's Avatar
Default Re: no vtec
Pull your carpet up and find out what kind of ecu it is, there is a sticker on the side of it. The person may have just used an LS ecu and wired up vtec themselve's, and the wiring job might be fubar.
Old Jan 22, 2012 | 12:31 PM
Whiterice-gsr's Avatar
Default Re: no vtec
yup i would say wiring, i had a small brake in one of my vtec wires and i never was able to find it i ended up running 2 new wires right from the ecu to the solenoid, of course this was after i paid 100 bucks for a new solenoid lol. the oil leak could be the issue depending on how much it leaks but it would have to be a fairly large leak. if its intermittent my guess is the wires.
Old Jan 22, 2012 | 08:48 PM
JdmTypeRdc2's Avatar
Default Re: no vtec
Check your oil.
Old Jan 23, 2012 | 05:43 PM
Default Re: no vtec
thnks very much ill update yall an check the wring an stuff
Old Jan 23, 2012 | 05:55 PM
boosted_db8's Avatar
Default Re: no vtec
try changing the oil it could be too thin or could be the wiring too
Old Jan 26, 2012 | 07:03 PM
cmwalker's Avatar
Default Re: no vtec
^^^ if it only works sometimes i bet u need oil. these guys are right!
Old Jan 29, 2012 | 03:41 PM
Default Re: no vtec
so did fix your problem??? was it the leak?
Old Feb 1, 2012 | 03:59 AM
Default Re: no vtec
hey guys i checked all that u said an i sealed the solenoid..... the part that was leaking...i also checked the wiring and its ok an current is reaching the solenoid... the vtec engages more often now but still not all the time...the next think i wanna ask if the oil is tooo thin can that prevent it from engaging in vtec
S_StarGsr
Apr 29, 2017 08:24 AM
scottypippen147
Nov 16, 2010 03:35 PM
josh's ep3
Dec 8, 2008 05:59 PM
CTR_B
Mar 15, 2008 09:06 PM
