Can this be fixed/repaired?
Old Dec 5, 2005 | 11:59 PM
2ndName's Avatar
Default Can this be fixed/repaired?
The Integra that I just purchased has a flaw. It is showned below.
Basically the inlet for the screw to tighten the front bumper is broken. So it sticks out a bit. I tried messing with it, seeing if I can just push it in, but that does not seem to help. Any idea if it is possible to have that part repaired, or am I looking at a new bumper?
Old Dec 6, 2005 | 12:24 AM
allinone07860's Avatar
Default Re: Can this be fixed/repaired? (2ndName)
u can try riviets
Old Dec 6, 2005 | 01:00 AM
bg-33p's Avatar
Default Re: Can this be fixed/repaired? (allinone07860)
bondo it
Old Dec 6, 2005 | 01:27 AM
brad.'s Avatar
zip ties.....zip ties
Old Dec 6, 2005 | 04:51 AM
M Coop's Avatar
Hell yea, zip ties or maybe some self tapping metal screws, run them up through the bottom of the bumper and into the fender. Then take some silicone or something and cover it so it doesn't rust.
Old Dec 6, 2005 | 05:34 AM
btran's Avatar
Default Re: Can this be fixed/repaired? (M Coop)
I just fixed my civic with the same issue on both side with some platic repair stuff from auto part store.. work well so far..
Old Dec 6, 2005 | 05:42 AM
veggiemaster's Avatar
dont buy a new bumper for something like that. not even worth the trouble. I would just try and get one of those threaded clips that can slide over the sheet metal, then run a screw through that. or just do the zip tie trick.
Old Dec 6, 2005 | 05:44 AM
jDm_jeremy's Avatar
got the same prob...my front had an unfortunate meeting with a curb...i just pushed it back in...going to get a new front bump anyway
Old Dec 6, 2005 | 07:32 AM
JDM-EJ1's Avatar
Default Re: Can this be fixed/repaired? (veggiemaster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by veggiemaster &raquo;</TD></TR><TR><TD CLASS="quote">dont buy a new bumper for something like that. not even worth the trouble. I would just try and get one of those threaded clips that can slide over the sheet metal, then run a screw through that. or just do the zip tie trick. </TD></TR></TABLE>
Exactly, try alll the options that we've listed and if those don't work (and I don't see why they wouldn't) than buy a new bumper.
Old Dec 6, 2005 | 07:38 AM
awsnap's Avatar
Silicone will only HELP it rust. Trust me.
Old Dec 6, 2005 | 07:50 AM
.:JEROME:.'s Avatar
I would just use the correct screw but put a really large washer on it and when you tighten it, it should pull that section together because the washer head will catch some part of the bumper area that is not totally missing.
Old Dec 6, 2005 | 09:09 AM
2ndName's Avatar
Awesome. After the smog check, I will mess around with it a bit more. Thanks for all of the helpful advice.
Old Dec 6, 2005 | 09:17 AM
b20acura's Avatar
Default Re: (2ndName)
when i used to have my accord i had the same problem, i fixed it using tape, lol it was cheap but it worked. i just used to tape so that when i screwed it on, it stayed on.
Old Dec 7, 2005 | 03:54 AM
M Coop's Avatar
Default Re: Can this be fixed/repaired? (awsnap)
OK well you have to do something to keep it from rusting if you run a screw through it. Painting it would be best I guess, but anything would be better than leaving bare metal don't ya think?
Old Dec 7, 2005 | 04:01 AM
2ndName's Avatar
I was able to fix it by redoing the front bumper.
My question is, what kind of screws do I use if I want to screw in the wheel well black plastics onto the sides of the front bumper?
Old Dec 8, 2005 | 06:11 AM
M Coop's Avatar
If you use screws use something with a big head. I'd use zip ties.
Old Dec 8, 2005 | 12:27 PM
LSracing94's Avatar
Default Re: (b20acura)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20acura &raquo;</TD></TR><TR><TD CLASS="quote">when i used to have my accord i had the same problem, i fixed it using tape, lol it was cheap but it worked. i just used to tape so that when i screwed it on, it stayed on.</TD></TR></TABLE>
yeah i did the same with my integra...duct tape with a screw through it hahaha
Old Dec 8, 2005 | 12:35 PM
EL Vap133's Avatar
Use a big washer!
Old Dec 8, 2005 | 12:52 PM
maniefrizzle's Avatar
Default Re: Can this be fixed/repaired? (JDM-EJ1)
hey JDM-EJ1 is you avitar from final fatasy tactics? looks like it but never seen that job/class before. . .looks like a bird costume with a really big beak facing backwards lol.
Old Dec 8, 2005 | 02:14 PM
tilt's Avatar
There is a metal bracket/stiffener that is behind the bumper. Maybe that is bent so the bumper is being pushed out. If so, you can take the bumper off, bend the bracket into shape or get a new one. If it isnt the stiffener, you can buy the plastic tab and screw that goes into the bumper from the dealer, or be cheap like me and zip tie the bumper to the fender.
Old Dec 8, 2005 | 02:15 PM
Sar Face's Avatar
bumper reapair, its like 8 or 9 bucks at a local paint store. Then use a mixing stick tape it to the area your fixing, apply the goo,let it dry and then just sand off any left over. It will be good as new
Old Dec 8, 2005 | 02:36 PM
beavis's Avatar
zip ties are you best friend. as well duct tape. all joking aside, use zip ties
Old Dec 8, 2005 | 02:50 PM
2ndName's Avatar
Yea, I will try to zip tie them. Thanks!
Old Dec 8, 2005 | 03:03 PM
DAcraze's Avatar
i agree qith zip ties
Old Dec 8, 2005 | 03:41 PM
yee SERIOUS's Avatar
Default Re: Can this be fixed/repaired? ([626]96.GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [626 &raquo;</TD></TR><TR><TD CLASS="quote">96.GSR]zip ties.....zip ties</TD></TR></TABLE>
that's always my answer
