how much to replace a camshaft seal?
does the camshaft need to be removed to do this?
or is this a simple fix?
1 Post
Re: how much to replace a camshaft seal? (92integraVTECgsr)
yes you need to take the cams out
if you did it you self the seals would only cost a fdw bucks
to pay some one to do it right. pull the cams out retorque everythting and do a valve adjustment it probably would cost close to $200
Re: (racekar711)
duh.. stupid me.. im talking about the camshaft end cap? that goes on the exhaust camshaft.. the rubber end cap.. damn im stupid.. well no, it was late last night and i was tired.. and didnt realize until he mentioned taking off the cam gears and sliding it in.
no you dont need to take the cams out.. take the valve cover off and the cam cap, take out the seal, put the new one in and torque the cap and valve cover down
the end cap by the vtec solenoid is easy to replace. remove valve cover, remove the cam cap and install the seal. the put everything back on. i should take around. 10-20 mins
Re: (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG »</TD></TR><TR><TD CLASS="quote">the end cap by the vtec solenoid is easy to replace. remove valve cover, remove the cam cap and install the seal. the put everything back on. i should take around. 10-20 mins</TD></TR></TABLE>
yeah... i also mistook it for the cam seal.
it doesnt cost much to change that maybe like 50 buccs
here is what i have for sale
digital audio amp 300 watts
http://i24.photobucket.com/alb...5.jpg
fusion alarm
http://i24.photobucket.com/alb...n.jpg
rc injectors 440 like new!!!!
http://i24.photobucket.com/alb...s.jpg
Modified by 23snorub at 3:37 AM 12/9/2005
fusion alarm
Re: (iakona)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iakona »</TD></TR><TR><TD CLASS="quote">and don't forget the hondabond!</TD></TR></TABLE>
they are too pricey for the size
