Speedometer problem!
Old Dec 7, 2005 | 01:21 PM
EL Vap133's Avatar
Default Speedometer problem!
After several years of working fine, this morning out of the blue my speedometer is acting weird. The speed needle is very slow, takes forever to register my actual speed, then I slow down to a stop and the needle stays at around 20mph for a bit (while stopped) and then it goes to 0 finally.
My odometer as far as mileage works still, and my temp/fuel gauge still work too. So is my speedo toast or should I check the thing on the tranny that goes into the speedo (forgot the name of it all of a sudden)?
car: 1997 Integra RS 5-speed.
Old Dec 7, 2005 | 02:36 PM
gsrthomas's Avatar
Default Re: Speedometer problem! (EL Vap133)
Could be your speed sensor which is on your transmission or it could be the guage itself.
Try to locate and replace the speed sensor. if that doesnt work then its 100% certain its the guage.
Old Dec 7, 2005 | 02:39 PM
Johnny_Rocket's Avatar
Default Re: Speedometer problem! (gsrthomas)
Speed Sensors are not cheap. I got a quote on one for my DA and it was close to $275... Do you have an actual spedo cable or is it electronic?
Old Dec 7, 2005 | 02:43 PM
projectTeG's Avatar
dc model tegs are electronic vss, 90-93 tegs and below are mechanical vss
Old Dec 7, 2005 | 02:57 PM
EL Vap133's Avatar
Default Re: Speedometer problem! (JohnnyH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnyH &raquo;</TD></TR><TR><TD CLASS="quote">Speed Sensors are not cheap. I got a quote on one for my DA and it was close to $275... Do you have an actual spedo cable or is it electronic?
My bad, I was thinking about my CRX. Yes my Teg does have the stock electronic vss.
Old Dec 7, 2005 | 03:22 PM
LSvtec03's Avatar
maybe there is dirt or something obstructing the needle. try to clean it out and see if that helps at all. after that, maybe i would try the vss, but i sure as **** wouldn't pay $275 for one.
Old Dec 7, 2005 | 05:29 PM
EL Vap133's Avatar
Default Re: Speedometer problem! (LSvtec03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 &raquo;</TD></TR><TR><TD CLASS="quote">maybe there is dirt or something obstructing the needle. try to clean it out and see if that helps at all. after that, maybe i would try the vss, but i sure as **** wouldn't pay $275 for one. </TD></TR></TABLE>
Nah I doubt it's dirt.
Old Dec 7, 2005 | 05:52 PM
gsr dood's Avatar
i had a loose connection on mine....i took a wire brush and brushed the **** out of it....i think it was jusst a little rust/greenish/corroding **** that got caught on the connection....works fine.....my brother actually just got a GSR vss off ebay today for 22$
Old Dec 8, 2005 | 10:35 AM
EL Vap133's Avatar
Default Re: Speedometer problem! (gsr dood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr dood &raquo;</TD></TR><TR><TD CLASS="quote">i had a loose connection on mine....i took a wire brush and brushed the **** out of it....i think it was jusst a little rust/greenish/corroding **** that got caught on the connection....works fine.....my brother actually just got a GSR vss off ebay today for 22$</TD></TR></TABLE>
Where did you clean it at?
mr. biggles
Apr 11, 2007 06:59 AM
rerun07
Dec 8, 2005 08:21 AM
951dc5
Feb 13, 2005 10:48 AM
gatoracer
Jan 14, 2003 05:52 PM
PSU
May 11, 2002 10:30 PM
