LS/Vtec Header Problem
Old May 4, 2013 | 11:55 AM
I3lakeintegra's Avatar
Default LS/Vtec Header Problem
I purchased a Megan 4-2-1 Header for my lsvtec motor (Gsr head/ls block) and it will not clear the oil pan. I searched and people said the b series are all interchangeable its just a little longer or shorter to the cat. Anyone else have this issue? Any help on which header I need instead would be appreciated. Thanks
Old May 4, 2013 | 12:01 PM
B_Swapped93's Avatar
Default Re: LS/Vtec Header Problem
That's true.
can you take a pic and show where/by how much it's hitting i'd say return it megan isn't the best brand imo a cut or so above DC.
Old May 4, 2013 | 12:25 PM
Originally Posted by B_Swapped93
That's true.
Yea I know its not the greatest, I am going back to NA and dont have a stock header. Read people didnt have really any issue with megan header so went with it. Ill try take a pic of where it hits.
Old May 5, 2013 | 10:00 AM
stock pan ? you're going back to N/A onlything I can think of it hitting is where you weld the holes for the oil feed line ?
Old May 5, 2013 | 11:02 AM
DirtyDA9's Avatar
^^ you mean bung for return line. Sorry for being a ****, but I am German
OP, why are you ditching the turbo setup? Factory pistons? Or aftermarket with lowered compression?
lsvtecpower
15
Aug 20, 2008 09:02 AM
GenIIIMrDuece
Mar 21, 2008 08:17 AM
DocSean
22
Dec 22, 2004 09:21 PM
civickiller
15
Jun 18, 2003 11:33 AM
lsvtecivic
May 7, 2003 09:07 PM
