WTF is this??
Old May 11, 2013 | 07:42 AM
Kid-jdm-teggy's Avatar
Default WTF is this??
This is to the tps but its not a phillip or flat head. I need to readjust the tps but i got stuck here. Anyone know how to remove it?
Old May 11, 2013 | 08:09 AM
burnoutboy's Avatar
The Credible Hulk
Default Re: WTF is this??
You'll need to dremel a flat slot in it for a flathead. Only way I know of. It was never intended to be removed. When you buy a TB from Honda it always comes with the TPS attached.
Old May 11, 2013 | 10:15 AM
HondaPartsHero's Avatar
Technical Hero
https://honda-tech.com/forums/tech-misc-15/diy-how-calibrating-voltage-your-tps-sensor-2947986/
Old May 11, 2013 | 10:52 AM
Originally Posted by HondaPartsHero
Thanks so much!
Old May 11, 2013 | 11:08 AM
b18ctodab's Avatar
It looks to me like a rivet. possibly do to threads are damaged. I would grind the head down to the Center of being careful not to damage sensor across the center as wide as the bolt. it can now be pulled off and there will be like a stud there. if its not threaded then it is a rivet and would need to be drilled out. try and use a drill bit smaller to make very thin walls as the remainder of the rivit use a pick tool to break the thin walls out. Please use center tap if drill is needed to prevent drill bit from walking and causing damage. if by chance you don't understand this YouTube how to drill a hole in a metal pipe and see. its kinda like pre drilling a hole to help insure the bit dont move
Old May 11, 2013 | 11:25 AM
burnoutboy's Avatar
The Credible Hulk
I'm speaking from experience, not what it looks like. Just dremel slot it and unscrew it. Bam, done.
HondaPartsHero's post is awesome except if you don't destroy the screws in the first place you don't have to spend 30 minutes trying to find 2 more LOL.
Old May 13, 2013 | 05:02 AM
kyden's Avatar
there really should be no need to adjust it, if it hasn't been messed with before.
Old May 13, 2013 | 05:05 AM
m4xwellmurd3r's Avatar
yep those rivets are oem and as long as theres nothing wrong with the tps and its calibration is good there is no reason to touch it. honda did that from the factory to save people the headache of calibrating them
Posted from Honda-tech.com App for Android
Old May 13, 2013 | 06:10 AM
S2BumpsticksGSR's Avatar
That ear of the tps is broken clean off anyway- it's not going to seal back up properly. They're the same size fasteners as inside the distributor (tiny)
kitt
Oct 5, 2020 11:13 AM
akinas-crx
Nov 7, 2011 03:18 PM
itsjdmbradyo!
17
Oct 6, 2006 12:45 PM
JUN_H22A
Jan 12, 2006 09:25 AM
serious
10
Sep 17, 2002 10:14 PM
