H2B help
Old May 11, 2013 | 10:43 AM
JdmCrx209's Avatar
Default H2B help
I have ah few questions regarding the h2v swap...it's gonna be swapped into a 1990 integra...
Old May 11, 2013 | 10:45 AM
JdmCrx209's Avatar
Default Re: H2B help
In the top 2 picture what are they suppose to connect to? And the bottom left picture where does that hose connects to? Because on my b20v that I just finished up it goes to the iacv? But on this h22 the hose looks like it's to big to connect to the iacv? And the last bottom right picture where does that niple connects to?
Old May 11, 2013 | 12:30 PM
JdmCrx209's Avatar
Ttt
Old May 13, 2013 | 08:14 AM
JdmCrx209's Avatar
Ttt
Old May 13, 2013 | 12:12 PM
JdmCrx209's Avatar
Which intake manifold do I use? Looks like it won't clean the brake booster..or do I gotta change my brake booster? And what t/l bracket?
Old May 13, 2013 | 03:00 PM
JdmCrx209's Avatar
Pulley clearance
Old May 13, 2013 | 03:01 PM
JdmCrx209's Avatar
Front view
Old May 13, 2013 | 07:47 PM
JdmCrx209's Avatar
Ttt
Old May 14, 2013 | 12:16 PM
3rdtimecharmer's Avatar
10 Year Member
look in the H2B sticky thread. i got all my answers there and good people willing to help with your swap.
i used my stock IM. the fitment is very tight but it fits. my swap went into a 94 GSR. idk if theres a size difference from the 90 integras and the 94 integras.
good luck.
Old May 14, 2013 | 01:13 PM
xero_xero's Avatar
nice that the OP took time to post pics.
t bracket will be manual 90-93 b series Da.
Top right pic in first post is EGR. dont need it.
Bottom left pic in frist post goes to heater core.
Bottom right pic in first post goes to FITV on bottom of throttle body.
Old May 15, 2013 | 08:10 AM
JdmCrx209's Avatar
Since the engine is mounted time to take ah break n think what I wanna do to this motor in the mean time gotta swap manifold on this db8 n post it for sale!
Old May 15, 2013 | 08:14 AM
JdmCrx209's Avatar
Another thing I found out...cannot use stock traction bar so that has to go..n no front tranny mount either...the engine sits so close to the radiator support so it doesn't have much room up front...
Old May 15, 2013 | 08:16 AM
JdmCrx209's Avatar
One more question what alternator belt do I use? I have the alternator relocation kit with a gsr alternator
Old May 15, 2013 | 08:35 AM
kyden's Avatar
what traction bar setup are you going to use?
Old May 15, 2013 | 08:47 AM
10 Year Member
i used the stock alt. from my f20B and a alt. belt for the h22.
Old May 16, 2013 | 07:25 AM
JdmCrx209's Avatar
Traction bar I'm have to go with ESP! Can't till I sell my db8 more money into the db1
Old May 16, 2013 | 07:26 AM
JdmCrx209's Avatar
Should i use my stock H alt or use a n series alt?
Old May 16, 2013 | 07:28 AM
JdmCrx209's Avatar
Rbc with qsd adapters for 340$ good deal? If I decide to use a K series manifold what do I do about my iacv? And what fuel rail/injectors do I use ?
Old May 16, 2013 | 09:02 AM
10 Year Member
you can use your stock H alt. perfectly fine.
i bought an AEM fuel rail for H series and it works fine for me.
the QSD adapter for the RBC is a great setup. message SP_GARAGE
he might be able to help u out with a small discount. tell him brandon/3rdtimecharmer refereed you. i want to go with the k series manifold, makes good power, better over the skunk2. theres a thread somewhere about it. do your research, it will pay off...trust me.
Old May 17, 2013 | 06:53 AM
JdmCrx209's Avatar
Since i don't know much about wiring I dropped off both harness to a friend of mines and as soon As he's done with the harness it's fire in the hole! Manifold fit perfectly fine no issues
Old May 17, 2013 | 01:26 PM
10 Year Member
Old May 17, 2013 | 01:48 PM
JdmCrx209's Avatar
Going to pick up a rbc manifold with tb adapter n manifold adapter for 340$ good deal? What fuel rail and injectors do I use with the rbc manifold?
Old May 17, 2013 | 06:31 PM
JdmCrx209's Avatar
Can someone link me to a k2h manifold install? I've tried searching google but came up with nothing....I'm going to pick up the manifold n adapters tomorrow
Old May 17, 2013 | 11:41 PM
JdmCrx209's Avatar
Any actual write up on this install?
Old May 18, 2013 | 02:41 PM
JdmCrx209's Avatar
Ttt....what did y'all do bout the fuel line on this swap? It's on the opposite side..
