Fuel question
Old Apr 20, 2013 | 06:43 PM
Lozano1991's Avatar
Default Fuel question
Ok so I'm running a b20v
Gsr head with 00' usdm itr cams
High comp b20b. Compression with head bumped to 10:2:1
Skunk2 IM & 66mm TB, aem intake
96 spec itr header and cat, rsr cat back, going to buy better header and test pipe with a 2.5" exhaust for next tune.
Stock fuel rail and fpr. 255 walbro pump
I tuned my car and got 208 whp and 168tq
My tuner told me to get an adjustable fpr, but the question is..
Can I use the stock fuel rail for the adjustable fpr? How much pressure can the stock rail do or handle?
My tuner cut me off at 7k because after that my engine would get leaner.
Old Apr 20, 2013 | 07:47 PM
Lozano1991's Avatar
Default Re: Fuel question
No one knows?
Old Apr 20, 2013 | 08:50 PM
m4xwellmurd3r's Avatar
I believe you need an aftermarket fuel rail to use an adjustable FPR, but don't quote me on that.
By the way, if fueling is the issue, an FPR is a horrible bandaid to be honest.
If you're maxing out your injectors, you need to get bigger ones and get it retuned.
Old Apr 20, 2013 | 09:19 PM
Lozano1991's Avatar
My tuner said I could get more from an after market fpr on stock injectors.
And what about the rail? If I do upgrade injectors can I keep the stock rail?
Old Apr 20, 2013 | 10:01 PM
Don't do that. You're just going to kill your injectors if you over pressurize them.
And yes, you can keep the stock rail with aftermarket injectors as long as you get a set that are a drop in replacment.
Old Apr 20, 2013 | 10:30 PM
Lozano1991's Avatar
So 310s would be what I need?
Old Apr 20, 2013 | 10:52 PM
el crapitan's Avatar
you can run an adj. FPR on a stock rail.
TBH, i don't think you even need injectors at this point. you're running a fairly mild na setup
get the FPR in there. bump it up to 50psi. that should fair you well
what are you tuning with?
Old Apr 21, 2013 | 03:54 AM
Lozano1991's Avatar
I'm tuned on chrome, so what's the highest I can adjust the fpr on stock injectors if I ever needed to.
Old Apr 21, 2013 | 07:08 AM
unfortunately, i can not give you a solid answer on that. i do know that 50 is safe. but that's about all i can say
Old Apr 21, 2013 | 05:05 PM
Lozano1991's Avatar
Alright. Do you think I'll get gains from a test pipe,header,cam gears, and fpr?
Ohh! And what's a good but cheap (not really cheap) header? For my set up
Old Apr 21, 2013 | 05:31 PM
B_Swapped93's Avatar
Test pipe+header yes cam gears w/stock ITR's(usdm) no not worth it.
here's a good header (hytech rep) http://www.privatelabelmfg.com/produ...b20-header.htm
Old Apr 22, 2013 | 04:20 PM
Lozano1991's Avatar
Can some one confirm this ??
What about the adjustable fpr on stock injectors?
And for that header, do you have it?
Old Apr 22, 2013 | 07:05 PM
Cam gears are NEVER worth it with stock cams
and hytech rep are a good header.
GT500FTW
Jul 14, 2015 10:39 PM
carlos8
Nov 4, 2013 04:53 PM
jdmls88
Sep 11, 2006 12:17 PM
boostd92
Sep 2, 2006 04:00 AM
