Overheating issue
Old May 8, 2013 | 10:24 AM
SAMCRO08's Avatar
Default Overheating issue
whats up guys, i just recently built a b18c1 and with 125 miles on the motor, its starting to over heat a bit
The engine: Darton Mid deck sleeves
: Cometic head gasket
: new water pump, thermostat (all oem)
: autozone radiator, with 11 inch slim fan
: prestone 50/50 coolant
So far ive checked: there are no leaks, im only running 3 coolant hoses, top and bottom radiator hoses and the 90 bend from the thermo housing to the intake manifold. I bled the system. Fan is coming on, i even jumped fan to try and keep it cool. Block and head were decked prior to install
Issue: While im driving for say 20 minutes.. it starts to warm more than normal
thoughts of issue: Need different type of coolant with darton sleeves
: maybe fan is too small, its only 11 inch
: maybe cometic head gasket is leaking, ive read issues on these before, machine shop recommended it for this type of sleeve
: i have arp studs but never went back and retorqued after the 10 heat cycle
any other ideas or solutions please help
Old May 8, 2013 | 11:52 AM
Former User's Avatar
Default Re: Overheating issue
You're missing most of these hoses?
Old May 8, 2013 | 01:18 PM
SAMCRO08's Avatar
yes, my old set up ran without these hoses also.
Old May 8, 2013 | 01:20 PM
Even the connecting pipe?
Old May 8, 2013 | 01:28 PM
SAMCRO08's Avatar
yes sir, im running an edelbrock victor x manifold, The only hoses im running are top and bottom radiator hose and that almost 90 degree hose connected to the intake manifold
Old May 9, 2013 | 08:14 AM
SAMCRO08's Avatar
any body with any other ideas
Old May 9, 2013 | 08:29 AM
S2BumpsticksGSR's Avatar
Where on temp gauge is it sitting? Do both hoses measure almost same temp(use laser thermometer if you can). I retorque my head bolts for peace of mind. Not to insult-Did you use proper torque sequence/2- step method?
Old May 9, 2013 | 08:32 AM
SAMCRO08's Avatar
the temp gauge is stock in the head. And yes sir i followed oem head torque sequence and used arp torque specs. I checked my oil for coolant but i dont see any. I read up on Darton Mid Sleeves dropping and or leaking
Old May 9, 2013 | 08:33 AM
SAMCRO08's Avatar
oh sry i miss read that. On the gauge its sitting right past normal temp and rises and lowers a tad during driving. Hondata says its about 208 degrees and threw an error code
Old May 9, 2013 | 08:48 AM
I would check the hose temps to verify t-stat/radiator is working properly. What code did it throw? When I bleed air out I bounce up/down on the doorsill to "rock" out any air pockets while bleeder is open slightly and idling.
Old May 9, 2013 | 08:53 AM
SAMCRO08's Avatar
hondata sent a code in the error report. Engine overheating. Im starting to think that the radiator fan is too small its only 11 inches and isnt pulling the hot air out enough. I placed my hand near it when it was on and it was barely blowing. The fan comes on because the thermo stat is opening. Its brand new oem, but i guess it could be bad
Old May 9, 2013 | 09:16 AM
The temp range of hoses will verify t-stat is good(most likely is). Are you running 1/2 rad or full? My full rad activates 2 fans(side by side) when t-stat opens(oem harness/relays).
MrMug3n
Honda Civic (2001 - 2005)
27
May 1, 2012 10:29 PM
project-boosteD
Jun 29, 2011 12:25 PM
project-boosteD
Jun 29, 2011 03:53 AM
slamLOWnBANGIN
43
Feb 28, 2010 06:01 AM
aziaticvang
18
Jan 29, 2008 02:16 PM
