Temp Gauge Not Reading Correct
Re: Temp Gauge Not Reading Correct
the wiring could also be shorting to ground. i believe with the sender, when grounded, the needle goes pegged. and given it's location, the wiring insulation is extremely susceptible to becoming brittle and cracking, leaving the strands exposed
if it is a 92 to 96 prelude then you should look into the actual dash gauge cluster assembly. the fuel gauge and temp gauge assemblies tend to tear up and the temp will read hot like it is overheating although nothing is wrong and temp is at normal.
Dmascarenasp
Honda Civic (2001 - 2005)
03-14-2016 11:15 AM
97grnrs
02-17-2007 07:06 AM
