overheating problem
Old Apr 21, 2013 | 09:45 PM
kodylive's Avatar
Default overheating problem
so my integra has been overheating it been geting between half a max h it starts doing it when i drive across town or on the freeway my fans both work pefect my radiatior fluid is good the temp will go between half and h and usal drops down to half/normal any ideas on what it is?
Old Apr 21, 2013 | 09:56 PM
slowDB7's Avatar
Default Re: overheating problem
possibly air bubble in your cooling system
Old Apr 22, 2013 | 06:01 AM
fcm's Avatar
fcm
Old Fart
Sounds like maybe a sticking thermostat, replace the thermostat and bleed the system till all air is out of it. 94
Old Apr 22, 2013 | 05:37 PM
kodylive's Avatar
not thermostat and I also blead the system what els could it be?
Old Apr 22, 2013 | 05:43 PM
Fliptard's Avatar
bad headgasket
Old Apr 22, 2013 | 06:06 PM
racebum's Avatar
thermostat and HG are the two most common causes of this
if it's a gsr/itr the headgaskets don't blow, they only leak if something is warped or bolts stretch
Old Apr 22, 2013 | 10:12 PM
kodylive's Avatar
my car is not smokeing at all and I have perfect power
Old Apr 22, 2013 | 10:16 PM
kodylive's Avatar
and no water in the oil
Old Apr 22, 2013 | 10:19 PM
slowDB7's Avatar
how old is your thermostat?
Old Apr 23, 2013 | 06:09 AM
fcm's Avatar
fcm
Old Fart
If you are sure it's not the thermostat, or the HG, and no air in the system, that only leaves the water pump or a restriction.
As asked, how old is the thermostat, and how do you know it's not the thermostat?
FYI, even a brand new thermostat can be DOA. 94
Old Apr 23, 2013 | 09:59 AM
m4xwellmurd3r's Avatar
A good way to check for a blocked up radiator, try to feel for cold spots (with the fans off)
If you have access to one of those laser temp sensor thingies, you can find the cold spots really quick. My old Z had a blocked up radiator. Took me quite a while to figure it out.
Old Apr 23, 2013 | 10:17 AM
KidKavika's Avatar
How old is your water pump and timing belt? Sounds like it could possibly be related to a dead water pump not circulating properly at higher rpms than 2,700
Old Apr 23, 2013 | 10:18 AM
KidKavika's Avatar
Just a suggestion.
Old Apr 23, 2013 | 07:11 PM
kodylive's Avatar
so I did some work on it today rebled the raditor and drove a took longer the usual to overheat it only got up to a tad over half after a long drive came back home to discover my fans were coming on and off non stop so I manualy had my fans on at all times and now my car doesnt overheat at all unless I come to a stop after a long drive and only goes to half and drops back down
Old Apr 24, 2013 | 06:12 PM
kodylive's Avatar
never mind still overheats just takes a long time to now
Old Apr 25, 2013 | 08:25 AM
cvcrcr99's Avatar
Jumping fans to run constant is a bandaid lol. The fans were turning on and off constantly due to the flucatuating temps.
It would hit the temp to turn on, cool down to the "off" temp, then quickly see that the temp was rising again, turning them on.
Overheating only when driving on highwayIMO would be an air bubble in system, Tstat sticking closed slightly, air flow blockage (do you have a huge FMIC in front of the radiator?), or water pump. I deal with cooling systems all day everyday for work.
Old Apr 25, 2013 | 06:41 PM
kodylive's Avatar
not my tstat and Im going to replace all my radiator fluid this weekend the only thing in front of my radiator is my ac thing.hopefully noten big because it overheats on the highway more
Old Apr 26, 2013 | 11:22 PM
racebum's Avatar
the fans helping are a good indication that it's the radiator that's the problem. since it's summer and you're doing a flush, just add water, no anti freeze. it lets you test the system and water is a better coolant than anti freeze anyway
sounds like you'll be getting a new radiator. scaling, blockage or being full of crap can kill their ability to relieve heat
when you replace the radiator make sure you take an air hose or garden hose to the AC condenser. they get plugged full of sand and debris which limits air flow to the radiator
koyo oem replacement radiator is like $100 so at least it isn't costing you much
Old Apr 27, 2013 | 03:36 AM
dont use just water. itll ruin crap as there is no anti corrosion additives in water. i believe optimal mix for cooling is about 30% antifreeze and 70% water
Posted from Honda-tech.com App for Android
Old Apr 27, 2013 | 03:54 AM
newfie_boy's Avatar
if u are flushing it out u should clean the heater core too
Old Apr 27, 2013 | 10:35 AM
racebum's Avatar
the engine will corrode in a day?
i'm not sure if you read the thread but the idea was to test, not permanently leave water in the system
Old Apr 27, 2013 | 10:55 AM
pimpwagon's Avatar
How do you know it's not the thermostat? Don't tell me you just replaced it. The only way I'd accept that as an answer is if you just replaced it with a honda OEM one. Did you put the one you think to be good in a pot of water and test it. I've had brand new ones stick on me...
Old Apr 27, 2013 | 10:59 AM
pimpwagon's Avatar
This is good advice if the rad is bad. Be sure to have the heat set to hot to properly flush out the heater core. Alot of the time they get the most gunky because most people dont circulate the antifreeze through them when it gets warm out. **** just brews in the heater core and gets nasty.
Old Apr 27, 2013 | 11:01 AM
JPhilBradley's Avatar
Just because the fans cut on doesn't mean they work "perfectly". Have you (VERY CAREFULLY) put your hand in front of it with it on to make sure it's moving a good amount of air? Even the slightest play in the bearings will allow it to wobble a little and can DRASTICALLY hinder air flow from it.
Just a thought...
Old Apr 27, 2013 | 02:06 PM
racebum's Avatar
i actually have two oem fans in outstanding condition along with various radiator hoses that have been on the shelf for years that i'd be happy to sell for $20 + shipping should anyone need them, or if you live around portland or, we can meet up.
anyway, cooling systems are easy to diagnose. the actual testing is a pressure test to make sure you don't have a leak somewhere. typically you start losing coolant if you do, so, if that's not happening you move on to the usual suspects
1. the thermostat. always use an oem honda thermostat! they aren't expensive and function correctly.
2. flush the system. this should be done when you pull the old thermostat for testing. what you do is pull the old stat, bolt the neck back on, put a garden hose in the radiator, fill, run the motor a few minutes, drain and repeat. when only clear water drains you have gotten all you can. now you have to get distilled water back in the system so you fill with distilled, run it, drain it then pull the stat housing to install the thermostat. next you get that garden hose and spray the **** out of the radiator and AC condenser to get anything trapped in the fins out. personally i'm a fan of removing the radiator since it's so easy to do and flushing it that way. you also have better access to the condenser. once this is done, fill again with distilled water and drive for a bit and see if the cooling system works. if the fans were suspect you can test them off a battery charger while on the bench during your flush to see if they grind or move air like they should. this flush cycle also lets you make sure the water pump is circulating like it should
3. if you still have heat problems and it's the radiator the car should run coolest about 50mph in 5th gear since you have forced airflow. when you slow down in traffic temps will rise and if the fans don't keep it in check you either have faulty fans or a faulty radiator. if you hard wire the fans and verify they are spinning at a good clip the radiator is all that's left. water scaling from not using distilled water is a major killer of radiators, when the tubes scale they do not work anywhere near as effective and rather than dissipate heat, they trap it
once you have identified the problem and replaced the parts get a gallon of coolant and gallon of distilled water, mix 50/50 and add.
the biggest reason i do not use coolant for testing is #1 it's $13 a gallon and #2 you have to be careful draining it, preserving it and making sure crap doesn't get in it. it also won't let you see as much crap during the flush cycle.
water you can drain in a bucket, on the ground, not a big deal
