Integra Frame Rail Replacement
Old Apr 19, 2013 | 08:34 PM
stwokay's Avatar
Default Integra Frame Rail Replacement
Hi, I'm looking to purchase a new frame rail and have a few questions. I just want to make sure the collision shop that I choose to go to is on the same page as me.
Okay, the items with a red dot is what I need replaced for sure. If I could avoid #27 (full set), that would save me some money.
Now my question is, for item #8, is everything circled in blue included? Or is only the outer piece included?
Also, can everything circled in blue be replaced without needing to replace everything circled in green (#5), if it is of course undamaged? From looking my car, is appears, everything circled in blue is welded on the outside.
Thank you for your help.
Old Apr 19, 2013 | 09:04 PM
fcm's Avatar
fcm
Old Fart
Default Re: Integra Frame Rail Replacement
Any one piece with a part number can be ordered as an item, any set can be ordered as a set, they will not remove parts you do not need, [they will, but you will still pay for the full set].
A set inside of a set can be ordered as just that set.
In your case you can order #5 by itself and #5 comes with #27.
A part inside a set that does not have a part # is only avalable in the set, in your case #8 does not include the inside.
I would order #20 and #27 and replace it all, probably less work.
Also, are you saying the only damage is to the parts you marked in red, and there is no damage to #10, if so, what happened? 94
Old Apr 19, 2013 | 10:04 PM
stwokay's Avatar
Wow, there you go again, answering my questions! Thank you FCM. I will not be ordering #10 because I will be purchasing a JDM front end conversion. My ITR was totaled by insurance and I'm trying my best to price everything out to see if it's worth bringing back to life. I guess I will have to purchase #27 for the full rail and possibly #20, I need the shop to look at the strut tower first though. I thought I could get away with #40. Thanks.
RA101724
Northeast (Sales)
Apr 4, 2011 05:00 PM
STRAN
Northern California (Sales)
Jul 20, 2010 11:32 PM
