Emission fail
Old May 9, 2013 | 07:25 PM
EdwinCheng's Avatar
Default Emission fail
Hey guys.
I went to emission test for two time. I still fail about the Co%. I was higher than the limit. What is that happen? I got j'racing air intake b18c1 engine. i got no idea how to fix it right now. Can someone give me some suggestion? because i dont want to do the waiver to pass ..
Old May 9, 2013 | 07:35 PM
S2BumpsticksGSR's Avatar
Default Re: Emission fail
We have no idea either. This is too vague. We need more info- Year Make Model, cat converter? How many miles, when was the last tune up, etc.
Old May 9, 2013 | 07:43 PM
EdwinCheng's Avatar
1995 acura integra gsr
it have around 88888mile.
the cat converter is the oem one.
i just buy this car for a week.
Old May 9, 2013 | 07:53 PM
EdwinCheng's Avatar
bump
Old May 9, 2013 | 07:55 PM
Check engine light on? What state are you in? What are your limit and actual CO and NOX #'s? This can point towards the problem.
Old May 9, 2013 | 07:58 PM
B_Swapped93's Avatar
Do you have the sheet they gave you when you failed ?
Old May 9, 2013 | 08:30 PM
EdwinCheng's Avatar
The check engine light was off. I am in Washington state.
Here is the first time
After that i find one of the auto repair shop. he tune it to the max
Here is the second time.
Old May 9, 2013 | 08:34 PM
bufalo123's Avatar
aight so heres the cheater way to get your tabs....go to the dmv and tell them that your car is non running...iv done that for the past two years and i always get my tabs....they will ask you why its not running so just tell them blown head gasket or something just make a believable story out of it and you should be fine....i too live in washington and like i said has worked for me and few of my friends
Old May 9, 2013 | 08:36 PM
EdwinCheng's Avatar
I have that sheet with me. I already post it. I want to know if the lower temperature will effect the CO?
Old May 9, 2013 | 08:45 PM
EdwinCheng's Avatar
I am not trying to get the tabs. I just buy this car. i want to transfer my name to the car..
Old May 9, 2013 | 08:46 PM
DazeMS's Avatar
change your spark plugs.. and your airfilter.. you are not off by much at all..you should pass..
The engine being this cool won't allow the computer to correct fuel/ignition much to reduce emissions versus the temp it will reach with a new thermostat. Edit- now I see the pics lol- ya, not bad a tune up should fix
Old May 9, 2013 | 08:49 PM
DazeMS's Avatar
bumpstick.. i thin khe means outside temp. as no emissions place will test a car without it being at proper running temperature. he is running a bit rich.. a set of plugs and an airfilter should fix the problem..
Old May 9, 2013 | 09:46 PM
EdwinCheng's Avatar
I didnt change the spark plugs yet. My air filter is J racing one. I dont know it will effect it or not. but if i get the new one, it gonna be so expensive
Old May 9, 2013 | 09:50 PM
EdwinCheng's Avatar
before i fix the thermostat, i was driving about 10 miles.
I buy the thermostat in autozone
http://www.autozone.com/autozone/par...6_0_1620_93207
after i change the new thermostat, i drive more than 10mins in freeway
Old May 9, 2013 | 09:53 PM
EdwinCheng's Avatar
Can i have something to clear the J racing air filter?
Old May 10, 2013 | 06:16 AM
About the only thing you can do is take the filter off and tap it against something like a tire or blow it lightly w/compressed air(be very careful, though, air filters are easily damaged from compressed air, so hold it maybe a foot or two away from air nozzle). The spark plugs to get are NGK PFR6G-13 or PK20PR-L13 Nippondenso (per service manual)
Old May 10, 2013 | 07:51 AM
DazeMS's Avatar
either your gauge is faulty( unlikely) or your coolant sensor is bad. and yes, a dirty air filter will cause a slight rich condition and old plugs will do the same. I gained over 3ftlbs and 3 hp , just by switching out the plugs on a dyno.
Old May 10, 2013 | 07:56 AM
Ya, it should be reading slightly less than halfway after its warmed up. Edit- it gets cold up that way, but it would reach at least 1/4-1/3 up the gauge @ idle, stationary. That's only about 1/8 on gauge...
Old May 10, 2013 | 09:12 AM
EdwinCheng's Avatar
I will change it and clear the air filters today. thank you
Old May 10, 2013 | 09:13 AM
EdwinCheng's Avatar
How can i replace the coolant sensor? there just have only one coolant sensor or few? Do you have some picture that can show me?
Old May 10, 2013 | 09:30 AM
EdwinCheng's Avatar
I want to know can i use thermostat from autozone?
Old May 10, 2013 | 10:11 AM
Just get the premium one+ new gasket. Install it without excess sealant on gasket. Scrape out any buildup in/on the gasket surfaces and place t-stat in the correct position. The spring side points to the engine and the pin in the flat plate points straight up. You'll leak out most of your cars coolant when doing this so you might want to also get a jug of antifreeze.
Old May 10, 2013 | 10:37 AM
EdwinCheng's Avatar
I did it yesterday, but its not really work. I am not sure its because of the autozone thermostate problem, or the senor. Do i really have to buy the oem one?
Old May 10, 2013 | 10:42 AM
I don't, I just get the premium one from parts house- that's what I meant above. Probably a bad sensor like other guy said
