Throttle getting stuck
Old Apr 25, 2013 | 06:26 AM
JDMarkLangston's Avatar
Icon2 Throttle getting stuck
I'm not sure what to do with this one. Needs some suggestions.
When I'm driving my throttle will get stuck at 3000rpm and I gotta dig it out with my foot. After riding and comin to a stop it idle at 1000-1300 up and down.
Then I dig it out with my foot and it sits at 1000. I've adjusted the throttle cable several times. I've put wd40 on the actually spring and it didn't help. Lol
Old Apr 25, 2013 | 06:48 AM
kyden's Avatar
Default Re: Throttle getting stuck
have you cleaned the throttle blade? are you sure the cable is moving freely?
Old Apr 25, 2013 | 09:52 AM
S2BumpsticksGSR's Avatar
Exactly- carbon buildup inside throttle body. With the engine running and intake tube off, spray intake cleaner inside the throttle body while throttling the engine by hand(to keep it from stalling and vary the degree that its opened). After this, shut it down. Now clean whatever is left out by hand.
Old Apr 25, 2013 | 12:34 PM
The cable moves freely and I haven't tried cleaning the throttle body. I figured me being able to pull the gas pedal out that it was something to do with the cable?
Old Apr 25, 2013 | 02:03 PM
I bet the throttle plate/bore is all crusty w/carbon buildup. 1-2 hoseclamps removed is all that's required to peek in there. Clean iacv next, its most likely the idle issue.
Old Apr 25, 2013 | 07:35 PM
Blackhalo6's Avatar
When you dig the pedal out its pushing the cable. The way the cable is mounted to the throttle I don't think it can push it shut. My guess is your pedal is sticking. Get down there and check it out. You can separate the cable from the throttle and then move the pedal and throttle independently and that will let you know what is sticking. It also could be damage to the cable itself.
theresyourproblem
Oct 4, 2007 09:28 AM
SpeedoKing
Aug 6, 2007 03:09 PM
Cute EK
Nov 15, 2005 06:18 PM
frostcivic
Oct 12, 2004 03:52 AM
rasta420
15
Mar 15, 2003 05:38 AM
