o2 problems
Old May 1, 2013 | 09:16 PM
calicuredtege1's Avatar
Default o2 problems
i have a 97 integra with a b18b swap in it and when i connect the upstream o2 sensor everything shorts out is it a bad o2 or could it be a bigger problem?
Old May 1, 2013 | 09:39 PM
slowDB7's Avatar
Default Re: o2 problems
what do you mean by everything shorts out?
Old May 1, 2013 | 09:58 PM
ILOVEGIRLS's Avatar
Ditto.. more info needed.
Old May 1, 2013 | 10:12 PM
Like As Soon As I Turn The Key When Its Pluged In Everything Cuts Off And The Car Just Goes Dead Until I Unhook The Batery And ThE O2 And Wate A While Then It Starts Up Just Fine With It Unpluged
Old May 3, 2013 | 06:02 AM
el crapitan's Avatar
start by checking the wiring for shorting to each other and shorting to ground.
do you know how to do this?
Old May 3, 2013 | 06:27 AM
fcm's Avatar
fcm
Old Fart
Please explain "Everything Cuts Off And The Car Just Goes Dead"
Are you saying you have no power to anything at all, like no dome light, no park/head lights, no radio, no horn and so on, "no power at all"?
Or do you mean just "everything" related to the engine running? 94
Old May 3, 2013 | 07:36 AM
B_Swapped93's Avatar
I'd bet you wired something up wrong when you did the swap. but more info is needed.
http://www.ek9.org/forum/other-techn...bd2a-obd1.html
I can't find the sheet for wringing up the o2
Old May 3, 2013 | 02:47 PM
Yes Everything Electrical Like Lights Radio Everything And The Starter Doesnt EveN Click But Withe The O2 Unpluged The Car Runs And Drices Fine Just With A Check Light on
Old May 3, 2013 | 04:07 PM
can you take a pic of the wires going into the o2 and the connector plug. something is mixed up pretty bad to do that.
Old May 4, 2013 | 08:30 AM
hmm. that is an odd one. not sure what in the o2 sensor circuit could cause all of that. even if it were shorted. you would have blown a fuse. and the starter should still engage.
unless the main power feed, or possibly the ign. switch is shorting to the o2 wiring. but should have blown a fuse. maybe AM alarm related
Old May 4, 2013 | 01:43 PM
fcm's Avatar
fcm
Old Fart
If you are loosing all power, [nothing electrical works] then it can only be a main ground or main power.
Plugging in the O2 may be causing a short, but it in no way explains why you loose all power, things like dome light, park/head lights, brakes and horn are all constant powers, [hot at all times] and do not require ign. switch to be on.
I would start by redoing your main grounds, DO NOT just eyeball them, disconnect/clean/reconnect, the batt. neg.(-) post and cable clamp, batt to chassis ground and chassis to engine ground.
You may well have other problems in relation to the O2 sensor wiring/plug, or possibly the sensor itself, but untill you redo the main grounds you can not elliminate them as the problem.
The 97 Integra uses a heated O2 sensor, power for the O2 sensor, [yellow/black] is supplied by the fuel injector relay in the PGM-FI Main Relay.
O2 sensor wire colors..
Yellow/black -12V+ with ign. switch in run and start.
Orange/black - ground
White/red - ECU/ECM, [O2S].
Green/blue - ECU/ECM, [SG2], the green/blue is common with the green/blue on the TPS, ECT sensor amd IAT sensor. 94
Old May 4, 2013 | 08:27 PM
Pao Thao's Avatar
Check ur fuse box if its not that then there is a short somewhere
crj_lll
Jan 5, 2014 07:37 PM
hondaccord
Jul 28, 2006 04:46 AM
AGENT 99
Mar 5, 2006 09:46 AM
zerovandez
Feb 5, 2006 01:56 PM
89JDMcrx
Jul 17, 2003 02:58 PM
