Cooling system question(s).
Old Apr 19, 2013 | 07:46 AM
B_Swapped93's Avatar
Default Cooling system question(s).
Was just wondering my t-stat got stuck closed several times lately so i ditched it and am currently running with out. But before open loop is mentioned my ECU runs constant open loop thus running off the chips fuel maps gas millage is fine tho(no primary o2 even). So other than that any reason not to get one asap i'll get a new one sooner or later but till then.
2nd my rad fan doessn't come on, jumped the fan switch plug comes on...do i replace the switch in the case(thing on the t-stat housing). thanks
Old Apr 19, 2013 | 08:07 AM
m4xwellmurd3r's Avatar
Default Re: Cooling system question(s).
The 2nd fan only comes on when the AC is on, so unless you run the AC, it won't come on.
Overcooling is the main issue with running with no tstat.
Over cooling is not a good thing. Go buy a new t stat and install it asap.
Old Apr 19, 2013 | 08:10 AM
Have no AC so that's how it's supposed to function(not come on at all ?). will grab new t-stat when in town then I guess.
Old Apr 19, 2013 | 08:19 AM
S2BumpsticksGSR's Avatar
Strange, in my 95, they both fire up simultaneously w/o a/c on. And, no, they're not rigged. They're plugged straight into the factory relays.
Op- I would test the fan relay before testing the switch by t-stat. Or you can ghetto wire your fans to acc key position by bypassing the relay with a jumper wire.
Old Apr 19, 2013 | 08:40 AM
doh I thought you were saying your 2nd fan doesn't come on.
But you meant 2nd, your fan doesn't come on.
Yes, replace your fan switch.
Old Apr 19, 2013 | 11:50 AM
got a stat will put it in tomorrow. yes i did notice the car was virtualy in the "cold" on the gauge during my whole trip to/from town 15 minute drive both ways. will replace fan switch at sum piont to but it never really gets hotter then +27C so like +80F in the summer here lol.
Old Apr 19, 2013 | 02:34 PM
808zrk's Avatar
I've always thought the condenser fan (driver side) comes on when your car gets really hot/ or the a/c is on?
Old Apr 19, 2013 | 02:57 PM
it should come on after a bit of driving/idling the one in my civic does at least. same with my moms FIT.
Old Apr 19, 2013 | 03:03 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
if they still wire them like they used to, it has a module that only lets the second fan come on after a certain temp,
Old Apr 19, 2013 | 05:28 PM
Replaced t stat as the car fell flat on it's face when i tired to start it tonight lol guess you DO need it. will get around to the fan switch to. do the 96-00 civic ones fit ?
Old Apr 20, 2013 | 10:07 AM
el crapitan's Avatar
with the t stat out, the fan won't come on. ever.
with the t stat in now, get it hot. see if the fan comes on now.
also, just so you know, ECT still plays a huge role in fuel delivery. regardless of being in open loop or not
Old Apr 20, 2013 | 10:57 AM
fan doesn't come on with it hot only when the fan switch plug is jumpped. ECT sensor is brand new and i fixed that running rich problem.
have yet to bleed the coolant sys fully properly just squshed the hoses a few times. temp gauge sits under half bu a bit is that normal
Old Apr 20, 2013 | 11:06 AM
Once more, ill point at the fan relay, there should be 2. 1for each fan. Mine have Always come on @ same time w/o a/c switch on.
Old Apr 20, 2013 | 11:07 AM
Replace the fan switch, make sure you burp it properly, and replace your rotor and cap. Try not driving it so much, because your rotor and cap are completely shot. I've never actually seen one wear out that badly in person (I always replace them at the first sign of ANY wearing out, which is usually more often than most people would replace them)
Old Apr 20, 2013 | 11:32 AM
I have no AC and if i push the ac button(not that it's connected to anything) still nothing happens engine was warm(gauge read a bit under half) can you tell me where the relay is i had trouble finding a diagram.
Old Apr 20, 2013 | 01:32 PM
In front of radiator(I know a stupid place) on drivers side hanging off top of core support. I know you don't have a/c. I was trying to say that both of mine turn on @ same time w/o(without) a/c on. I've never had just 1 activate on my 95.
Old Apr 20, 2013 | 01:45 PM
alright found it and what am i looking for with the relay ? shorted/burnt something like that ?. im horrible with electrics my appoligies
Old Apr 20, 2013 | 02:30 PM
Pull one that works from another car they're a common relay. Usually under hood in that fuse box. Swap it and see if it'll activate. I don't have my car handy r/now, sorry.
Old Apr 20, 2013 | 04:37 PM
if the fan comes on with the switch jumped, the relay, and everything besides the switch, is fine.
if the fan isn't coming on with the engine hot, the switch is bad.
Old Apr 20, 2013 | 05:01 PM
It's the switch then, the one in the t-stat housing(there's only one right)
this guy
Old Apr 20, 2013 | 07:58 PM
yes. that is the thermo fan switch
ls1formula98
Apr 14, 2015 06:05 PM
vondamp
Aug 30, 2007 06:08 PM
FOrSfEd
Jul 14, 2004 05:08 PM
