Tail lights...
Old Apr 26, 2013 | 10:33 PM
aaron_integra's Avatar
Default Tail lights...
First off, I have used the search....but found nothing with my same issue.
Left side, only the left side is having the issue. tail light / side marker not working in rear.
Brake / blinker / reverse light works.
All other lights on the car work.
Dash lights are good.
Bulbs are not blown.
Ideas?
Old Apr 27, 2013 | 05:31 AM
S2BumpsticksGSR's Avatar
Default Re: Tail lights...
In Washington there's a lot of humidity. This causes a lot of corrosion on electrical terminals.
I would say corrosion in the bulb socket or wiring harness
Edit:read closer- wiring harness(meaning damage to)
Old Apr 27, 2013 | 07:54 AM
I'll check that out...but for both to go out at the same time. (Marker and tail). I hope it's something obvious. Ugh.
Old Apr 27, 2013 | 09:51 AM
27whp_teg's Avatar
possibly check for wiring issues. Not sure if you use the car as a daily rive, but maybe a mouse/rat got up in somewhere and chewed some wiring.
Old Apr 27, 2013 | 09:26 PM
Blackhalo6's Avatar
My wife's da does this. I have no idea.
Old Apr 28, 2013 | 02:56 PM
FOUND IT. The white plug behind the cover. Remove the 4 plasic screw things, and then rmove the back plastic trim. Then you'll see the white plug. I honestly giggled mine around and now it's working. A temp fix until I can dig into cleaing it up / repalcing a ground.
Old Apr 28, 2013 | 03:07 PM
Hmm sounds like corrosion. I lived there for 5yrs and I remember having multiple issues w/lights and electrical bugs from all the rain and moisture. Use dielectric grease on everything electrcal there. It creates a barrier the water can't get through.
Old Apr 28, 2013 | 09:43 PM
Fair enough. Yeah.... other than the 2 months of summer and 6 random nice days, RAIN AL THE TIME.
Where did you move too?
Old Apr 28, 2013 | 10:05 PM
Blackhalo6's Avatar
Yea exactly! Thanks wa for ruining my friends first trip to a large auto congregation.
Old Apr 29, 2013 | 06:05 AM
I lived in the Longview area for 4yrs, then moved to Olympia for the last year. Its a little too good-ole-boy for me up there. I definitely preferred the college town/city area.
You might be able to use silicone for some of your more permanent connections. I do miss the scenery, the desert is just a dust bowl. Zona BUYS water from other states lol. Its like Mexico down here...close the border, enough is enough.
Old Apr 29, 2013 | 06:58 AM
fcm's Avatar
fcm
Old Fart
The ground is common for the left and right sides, [unlike in the front] so if one side is working properly, grounding is not the issue.
Corrosion is most likely the problem, easy fix...
Onplug the connector, spray WD40, [or any penetrating oil] into plug and socket, plug and unplug it a few times, clean up excess and plug back in, do the same on the other side as it is most likely also corroded.
For extra protection, pick up a tube of dielectric grease for extra protection...
https://www.google.ca/search?q=diele...w=1280&bih=868 94
Old Apr 29, 2013 | 08:05 AM
Ahh okay. I kinda know what you mean as far as Washington goes. Olympia moreso.
Cool! Thanks boss!
DJ3W3
Sep 22, 2010 05:46 PM
DJ3W3
Sep 13, 2010 12:12 PM
