Possible leak?
Old May 10, 2013 | 09:39 AM
Nick Durkin's Avatar
Default Possible leak?
Stock B18C1 GSR
There is a high pitched noise coming from the intake. No matter what rpm the motor is running at it is the same pitch and same level. When I take the intake off you can barely hear it if you put your ear close to it. The intake resonates the sound I guess so when you put your ear by the air filter you can hear it clearly. Is this some kind of vacuum leak or something? Should I run a compression test?
Thanks.
Old May 10, 2013 | 06:26 PM
boostmeup51's Avatar
Default Re: Possible leak?
I don't think it is a leak. It is some kind of electronic noise. When the car is off and the power is turned on you can hear the sound coming from the intake. It's a high pitched tone.
Old May 10, 2013 | 06:37 PM
B_Swapped93's Avatar
I know that noise never worried about it yes it's electronic. what or exactly from where I have no clue
Old May 11, 2013 | 07:58 AM
It would be nice to know though
Old May 11, 2013 | 02:15 PM
http://www.youtube.com/watch?v=Q5_hP...ature=youtu.be
Video demonstrating the sound. It is not the intake causing the sound because I can remove it and still hear it coming from the manifold itself. It is more annoying that the video makes it seem. I can hear the sound buzzing in my ear even from 10 feet away. It must be close to a 1khz tone because my ears are really sensitive to it. Very annoying. Any ideas?
Old May 11, 2013 | 04:52 PM
ok the noise im talking about is only on when the car is in (II) on the ign. can't hear it in the vid
Old May 11, 2013 | 06:33 PM
Yes the noise occurs only when in the second position and is very quite. When the engine is running however, the noise becomes significantly louder. I will see what I can do as far as audio analysis to better demonstrate what I am hearing.
Old May 11, 2013 | 08:22 PM
Okay check out the video
http://www.youtube.com/watch?v=qrJmq...ature=youtu.be
did some audio analysis to show you what I'm looking at. It's that really solid line at 500hz. I slowly faded out everything except frequencies around 500hz and then faded back into the original sound with all the engine noise. Hopefully now you know what I'm talking about.
Old May 11, 2013 | 08:25 PM
Blackhalo6's Avatar
i have it too, idk wtf it is, if u figure it out id like to know
Old May 11, 2013 | 08:26 PM
Almost sounds like the fan(from a distance) is the fan going I can hear the sound that you're talking about. try taking replacing the air filter who knows...
Old May 12, 2013 | 03:00 PM
On a nice day I'll take the intake off and do another video to show you that the air filter has nothing to do with the sound except perhaps maybe resonating and making it a slight bit louder.
Old May 13, 2013 | 01:22 PM
Couple videos here demonstrating the sound. I'm sure you can figure out what's going on in the videos. When the intake is off you can barely hear the sound but it is there. The sound resonates in the intake piping and that's why it is louder with the intake on. The sound is definitely coming from inside.
http://www.youtube.com/watch?v=yV3rz...ature=youtu.be
potatointegra01
Mar 14, 2016 12:07 AM
deadmemoryy
Dec 12, 2007 08:24 PM
jumai182
10
Oct 11, 2007 04:55 AM
BeerBaron105
Feb 1, 2004 08:33 AM
unltdacc12
Apr 4, 2003 07:54 AM
