Header questions..
Old Jan 24, 2007 | 07:21 PM
dc4_wHORE's Avatar
Soldering Iron Wizardry
Default Header questions..
I am looking for a header for my 2000 Ls, i am planning on doing a skunk 2 intake mani, and possibly some cams and headwork.... i have no clue what header to buy, i was looking at a DC 4-1 stainless, but i open to any suggestions....
Old Jan 24, 2007 | 07:26 PM
mrdeadman's Avatar
They let me pick
Default Re: Header questions.. (car_crazy_2007)
How much are you willing to fork out?
A turbo manifold will be cheaper in the end...
Old Jan 24, 2007 | 07:39 PM
raaawrz's Avatar
I'm going with SMSP.
Awesome header. Expensive though.
Old Jan 24, 2007 | 07:41 PM
numbnuts22715's Avatar
What are your goals for the car?
depending on how much hp you want to make, theres a few routes you can go.
Old Jan 25, 2007 | 05:03 AM
dc4_wHORE's Avatar
Default Re: (numbnuts22715)
I have looked into a turbo setup, but rignt now my teg is my daily driver, so it has to be reliable, i might go turbo later, but i was wanting to build the head now. overall right now i have about $1300 to spend on the IM, header, and possibly cams. I think i could get the head worked cheap...
dc4_wHORE's Avatar
Default Re: (raaawrz)
Do you have a link for the SMSP header?
Old Jan 25, 2007 | 06:22 AM
Type_RS_59's Avatar
Default Re: (car_crazy_2007)
If the car is a daily driver, you will probably want a 4-2-1 design instead of a 4-1. The 4-1 will give you more peak power at high RPM but the 4-2-1 will give you a nice fat midrange which is where you spend most of your time on the street. I've tried a few different ones and I eventually settled on the Greddy 1 piece stainless steel 4-2-1. I love it and my car is used for mostly auto-x and track days now. If I ever convert it to race ITA and/or H4 I'd go for the SMSP but in my opionion it's major overkill for a street car.
Old Jan 25, 2007 | 06:55 AM
dc4_wHORE's Avatar
Default Re: (Type_RS_59)
What about using the 4-2-1 with the skunk 2 intake main? cause the IM if designed for mid-hi rpm range power gains, would a 4-1 suite the IM better than a 4-2-1?
Old Jan 25, 2007 | 10:35 AM
Type_RS_59's Avatar
The bottom line is, what do you use the car for? Commuting, drag, auto-x, track, or show? If it's commuting or auto-x, get the 4-2-1. If it's drag or track, get the 4-1. If it's for show, get whatever is shinyest. I really don't see the point in getting the Skunk IM unless it's for drag, road racing or show. At least not before doing headwork, cams and throttle body.
Old Jan 25, 2007 | 06:51 PM
dc4_wHORE's Avatar
probably leaning more toward drag, i already got the hook up on the head work, i can get the cams and tb, thanks for your advice
Old Jan 25, 2007 | 07:15 PM
jdm_bones's Avatar
all motor LS for drag use....hahahahaha! Are you serious, you should just turbo your car...you are going to waste alot of money on a slow as motor
Old Jan 26, 2007 | 05:05 AM
dc4_wHORE's Avatar
Default Re: (jdm_bones)
i need it to be reliable tho
Old Jan 26, 2007 | 05:09 AM
dc4_wHORE's Avatar
i would be better off doing either a gsr swap, or boost the ls i have now
Old Jan 26, 2007 | 12:22 PM
dohcMONSTER's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by car_crazy_2007 &raquo;</TD></TR><TR><TD CLASS="quote">i would be better off doing either a gsr swap, or boost the ls i have now</TD></TR></TABLE>
neither, if you have a budget and want to make you LS faster then read around and search. Todd (B19coupe) made 175/145 on a budget LS build that only cost him around 1000 dollars and combine that with a b16 or typpe r tranny and i think you would be happy for a daily.
https://honda-tech.com/zerothread?id=1765855
https://honda-tech.com/zerothread?id=1862604
Old Jan 26, 2007 | 05:10 PM
dc4_wHORE's Avatar
Default Re: (dohcMONSTER)
thats good, i have right at $1300 to spend on it right now... i just need to do something to stay up with my friends. this summer i am planning to get another car, and prolly go boost with the teg i got now
b16a4
Apr 20, 2007 03:58 PM
blu3g
May 25, 2005 02:26 PM
kuki
Dec 24, 2004 02:36 PM
5-SpeedFreak
18
Jan 25, 2002 09:44 AM
