My seat got stuck!!! Won't slide back.
Old 01-24-2007, 06:12 PM
mike5809's Avatar
Default My seat got stuck!!! Won't slide back.
Hey I was puttin a new cd player and stereo in my 98 gsr (and what a pain - ive installed alot of systems, but this was a bitch). Anyway, I went and slid the passanger seat the whole way up so I could get in the back.
Well when I went to slide it back it only went about 2 nothces on the rail (about an inch). It is almost all the way up right now; The seat slides the rest of the way up about an inch or so. Then will only slide about an inch back. I looked under the seat could not see any obstructions under or behind the seat. When I lift up the lever under the seat to slide it back the little latches on both rails release from the rails, so thats not it. Like I said I can not see any obstructions at all, however, when I slide it back it sounds like it is hitting something on the right (door side) rail. It sounds like when you slide the seat the whole way back. Also the seat reclines perfectly.
What should I look for? Any help would be great.
Old 01-24-2007, 06:25 PM
arren123's Avatar
Default Re: My seat got stuck!!! Won't slide back. (mike5809)
Maybe you got a coin or something stuck in the rail that you can't see ?
If you can still get to all the seat bolts, you might want to try and take the seat out so you can take a good look at the rails and see what's stopping it.
Or, if you are absolutely sure that there is nothing in the rails and nothing is broken. You can try sitting in the seat and pushing it back really hard to see if it can get past the sticking point, but this might cause more damage if something is actually broken.
With that said. I'd try and take out the seat first.
Old 01-25-2007, 01:29 AM
mike5809's Avatar
Default Re: My seat got stuck!!! Won't slide back. (arren123)
Yeah - it looks like that is what i am going to have to do. Have not looked at it to see if I can access all the bolts for removel.
Any other thoughts before I do that?
Old 01-25-2007, 09:12 AM
mike5809's Avatar
Bump for being bored at work.
Old 01-25-2007, 09:54 AM
B18c5__Owns's Avatar
Location: I Bet You Really Want To Know Where In, NJ, USA
yea that happened to me. It was a coin
Old 01-25-2007, 10:03 AM
mike5809's Avatar
Default Re: My seat got stuck!!! Won't slide back. (B18c5__Owns)
Did you have to take the seat out to get it out to get it? Because I cant see anything, so the only thing I am guessing that it is stuck inside the rail?
Old 01-25-2007, 11:00 AM
b16er's Avatar
The cable that the lever pulls is either broken or popped off. Mine did this, I just unbolted the 4 bolts, pulled the seat out and fixed the problem. My cable had just popped off.
Old 01-25-2007, 02:18 PM
Hype-R Stalker
CleanLikeJdm's Avatar
Default Re: My seat got stuck!!! Won't slide back. (b16er)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16er &raquo;</TD></TR><TR><TD CLASS="quote">The cable that the lever pulls is either broken or popped off.</TD></TR></TABLE>
If the cable was broken, the one side would not move At All,
his moves back atleast two spots on both sides, so it couldn't be the cable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike5809 &raquo;</TD></TR><TR><TD CLASS="quote">When I lift up the lever under the seat to slide it back the little latches on both rails release from the rails, so thats not it. </TD></TR></TABLE>
Reading everything also helps.
Old 01-25-2007, 02:20 PM
qwk db8's Avatar
thats what i was thinking
Old 01-25-2007, 02:26 PM
mike5809's Avatar
Default Re: My seat got stuck!!! Won't slide back. (qwk db8)
Haha, yeah the cable releases both sides (both rails) thought it was kinda clear. But thanks for the help!
Old 01-25-2007, 02:28 PM
Hype-R Stalker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike5809 &raquo;</TD></TR><TR><TD CLASS="quote">Haha, yeah the cable releases both sides (both rails) thought it was kinda clear. But thanks for the help!</TD></TR></TABLE>
Try, and reach under there, the bolts are 12mm, get a wrench if a ratchet won't fit.
It will definitely be a lot easier to diagnose the problem then also.
Old 01-26-2007, 06:45 AM
95 integra's Avatar
Default Re: My seat got stuck!!! Won't slide back. (CleanLikeJdm)
Put a little force into it.....both feet in the floorboard pushing as hard as you can. If that doesnt work....take it out.
Old 01-26-2007, 10:23 AM
b16er's Avatar
Ok you got me. I am a illiterate bitch. Either way, pull your damn seat out and look. Its 4 bolts and takes 5 minutes. So I might have been wrong about the seat cable but I did give other advice. SEAT OUT!
Old 01-26-2007, 10:25 AM
OMG THE GOGGLES's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arren123 &raquo;</TD></TR><TR><TD CLASS="quote">Maybe you got a coin or something stuck in the rail that you can't see ?
Check for coins, one year, a penny got shoved into the shift assembly, and caused things to seize up...I take it all apart and flip it upside down to find a penny warped like the letter u. LOL
Old 01-26-2007, 10:58 AM
mike5809's Avatar
Default Re: My seat got stuck!!! Won't slide back. (gasp0matikz)
Ok thanks I am going to see if I can do that this weekend if I have time. I will let you guys know.
Thanks
Old 01-27-2007, 03:03 AM
dc2doi's Avatar
Got the same problem, I'm probably thinking a coin is stuck in mine as well.
Old 02-13-2007, 02:07 AM
arren123's Avatar
Mike,
Did you ever figure out what the problem was ?
Old 03-18-2007, 11:20 AM
mike5809's Avatar
Well I have taken the seat out, and still can't figure it out.
The one rail (not the one attached to the slide lever) gets stuck. It will slide about 2 inches in either direction then just stops. I cant see anything stuck in the rail so I dont know where to go from there.
Any idea what else I can try.
Old 03-19-2007, 05:54 AM
mike5809's Avatar
bump neone?
Old 06-09-2017, 04:14 AM
Creig Reed's Avatar
I have a 2011 Honda Accord with power driver seat. My seat will go but only half way back this is the second seat I put in it this month anyone have any ideas on how to fix this? does my driver's seat have a preset setting or something?
Old 06-09-2017, 07:02 AM
JDM-EJ698's Avatar
You do realize that this post was from 2007?
Bob Ragan
Honda Ruckus and Scooters
04-15-2018 05:06 PM
Outrun
05-07-2016 10:10 AM
shoklid
01-11-2010 07:54 AM
AJY
03-04-2005 07:16 PM
Toda Party
12-22-2001 12:26 AM
Quick Reply: My seat got stuck!!! Won't slide back.
