Tire problem
Old Jan 25, 2007 | 08:53 PM
o0oz's Avatar
Default Tire problem
i have 215s for tires and its been scraping on my wheelwell when i turn left...
my brother told me about bumper stoppers? im not sure what that is...
can someone explain? or should i just simpply get some 205s for tires....
the weird thing is... it only happens on my rear-right tire...
the others dont make noise or scratch..
any help?
Modified by o0oz at 10:34 PM 1/25/2007
Old Jan 25, 2007 | 09:40 PM
o0oz's Avatar
Default Re: Tire problem (o0oz)
bump
Old Jan 25, 2007 | 10:38 PM
twisted metal 2's Avatar
check your suspension if only one side is scraping
Old Jan 26, 2007 | 03:12 AM
roger93si's Avatar
yea suspension could be uneven.. i once had a hatch back and was hit on the right rear 1/4 panel fixed it, and ever since then my right rear tire was the only one that rubbed on turns. was yours ever hit???
Old Jan 26, 2007 | 07:55 AM
nsxtasy's Avatar
H-T Order of Merit
It's probably because your tires are too large. Here are the best fitting tire sizes for Integras:
On 14" wheels, 185/65-14 or 195/60-14
On 15" wheels, 195/55-15 or 205/50-15
On 16" wheels, 205/45-16 or 215/45-16
On 17" wheels, 205/40-17
If you're not using one of these sizes, that's why you're rubbing. Use the right tire size and it shouldn't rub at all.
Old Jan 26, 2007 | 10:26 AM
o0oz's Avatar
Default Re: Tire problem (roger93si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roger93si &raquo;</TD></TR><TR><TD CLASS="quote">yea suspension could be uneven.. i once had a hatch back and was hit on the right rear 1/4 panel fixed it, and ever since then my right rear tire was the only one that rubbed on turns. was yours ever hit??? </TD></TR></TABLE>
what u mean by 1/4 panel? and what u mean by ever hit? mine rub too... im planning on taking it apart to take a look at my stuff... i have a feeling it might be the stock orange rubber piece that goes on top of the strut that can be off-placed.... and also, when i turn into a driveway by making a right.. it doesnt scratch because im driving slow but it seems like my springs compress and makes a POP noise... i just know it doesnt sound good.
Old Jan 26, 2007 | 10:47 AM
nsxtasy's Avatar
H-T Order of Merit
What size are your tires?
Old Jan 26, 2007 | 01:28 PM
o0oz's Avatar
Default Re: Tire problem (nsxtasy)
215/45-17
Old Jan 26, 2007 | 01:29 PM
o0oz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">It's probably because your tires are too large. Here are the best fitting tire sizes for Integras:
If you're not using one of these sizes, that's why you're rubbing. Use the right tire size and it shouldn't rub at all.</TD></TR></TABLE>
i understand what ur saying but it doesnt explain y its only 1 tire that rubs when the other 3 doesnt... i have a feeling its my shocks... time to replace!
Old Jan 26, 2007 | 02:04 PM
nsxtasy's Avatar
H-T Order of Merit
Sure it explains it. YOUR TIRES ARE TOO BIG. They're 20 mm wider than stock and 5 percent (more than a full inch) larger in diameter - that's WAY too huge! It just so happens that they rub first in one particular wheel well. I'm surprised the other tires aren't rubbing too.
You are also experiencing several other problems due to using the wrong tire size. Your speedometer and odometer read low by 5 percent (that's a lot). And your car accelerates slower in each gear because of the larger diameter (it's like putting taller gears in your car).
Look at the calculated outer diameters of the various tire sizes and you can see why you're rubbing because of your oversized tires:
195/55-15 (stock on some Integras) 23.44 inches
195/60-14 (stock on other Integras) 23.21 inches
205/40-17 23.46 inches
215/45-17 24.62 inches
If you want to waste your money on shocks, go ahead. The fact is, your problem has NOTHING to do with your shocks. You need to get the proper size tires - 205/40-17 - and then your rubbing problem will be solved.
Old Jan 26, 2007 | 02:13 PM
o0oz's Avatar
sometimes it doesnt rub but i hear some kinda pop noise.. its like... my springs compress and then shot up... it sounds like a grind but i know its not rubbing... its another noise... think u can help me with that? cause even with smaller tires, it wouldnt rub but im sure i will still hear the noise... it happens when i make a right turn into a drive-way..
Old Jan 26, 2007 | 02:43 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by o0oz &raquo;</TD></TR><TR><TD CLASS="quote">sometimes it doesnt rub but i hear some kinda pop noise.. its like... my springs compress and then shot up... it sounds like a grind but i know its not rubbing... its another noise... think u can help me with that? cause even with smaller tires, it wouldnt rub but im sure i will still hear the noise... it happens when i make a right turn into a drive-way..</TD></TR></TABLE>
That does indeed sound like a suspension problem. But it might not be the shocks. (Ways to tell if the shocks need replacing are (a) if they leak fluid, or (b) if the car seems to bounce.) Put the car up on a lift and check out the suspension thoroughly. Noises like you describe can be the control arm bushings are worn/cracked, it might be a bent control arm, stuff like that.
mikebaker422
Jul 10, 2013 11:45 PM
Outlaw-Hondaz
Jun 8, 2011 12:00 PM
mac_24_seven
Apr 5, 2007 04:46 AM
Vracer111
Oct 30, 2001 06:05 AM
