How is the valve condition
Old Jan 26, 2007 | 01:52 PM
StolenTeg's Avatar
Default How is the valve condition
c
Modified by StolenTeg at 11:33 PM 4/28/2007
Old Jan 26, 2007 | 04:08 PM
H9Omega's Avatar
they look decent, you cleaned them all up before you took these pics right?
edit, im noticing they are kinda flat on some of the valves...
Old Jan 26, 2007 | 04:17 PM
StolenTeg's Avatar
Default Re: (H9Omega)
b
Old Jan 26, 2007 | 06:02 PM
dem0nk1d's Avatar
Default Re: (StolenTeg)
you can put water down the intake port, or exhaust port. if water leaks the val is bent or not making a proper seal. it's the gangster way of doing it.... water is thinner than oil..
Old Jan 26, 2007 | 06:34 PM
PLAGUED_DB7's Avatar
Default Re: (dem0nk1d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d &raquo;</TD></TR><TR><TD CLASS="quote">you can put water down the intake port, or exhaust port. if water leaks the val is bent or not making a proper seal. it's the gangster way of doing it.... water is thinner than oil..</TD></TR></TABLE>
nah man. u can hydrolock! lol j/k
wd40 works too
Old Jan 26, 2007 | 08:14 PM
CleanLikeJdm's Avatar
Hype-R Stalker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StolenTeg &raquo;</TD></TR><TR><TD CLASS="quote">I did not clean them yet, is it okay to use brake cleaner? How bout using brake cleaner on the spring/retainer area?</TD></TR></TABLE>
It's fine to put w/e you want in there long as it's cleaned up before you put it to use again.
Old Jan 26, 2007 | 08:52 PM
dem0nk1d's Avatar
Default Re: How is the valve condition (StolenTeg)
looks like the head has been ported or at least cleaned up from what i can see. looks to me the stock casting flaw has been taken out...
kb58
15
Jun 14, 2006 05:41 PM
EH2 on Steelies
16
Feb 28, 2006 12:15 PM
pcorad
Jul 4, 2005 07:40 AM
project dc2
Mar 15, 2005 06:33 PM
Jorsher
Oct 22, 2004 02:54 PM
