??????help???????
Old Jun 10, 2007 | 12:45 PM
1993gsrcivic's Avatar
Default ??????help???????
i will be like crusing in like 3rd 4th or 5th gear and then i will stomp the gas and then the motor will speed up, it will jump like 1000 rmps higher then it will drop and then the car will start to go faster
is this my clutch slipping?
Old Jun 10, 2007 | 01:24 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: ??????help??????? (1993gsrcivic)
Most likely the clutch is slipping. It is interesting that it slips when fully engaged and then quits slipping.
Old Jun 10, 2007 | 02:24 PM
DurtyVdub's Avatar
yeah i think the clutch is starting to go, its a hydro tranny.. so no cable adjusting...
Old Jun 10, 2007 | 04:28 PM
Default Re: (DurtyVdub)
yea its hydro but the clutch was replaced in august so it must have been a bad clutch
Old Jun 10, 2007 | 09:08 PM
Default Re: (1993gsrcivic)
how long will this last till its completely gone
Old Jun 10, 2007 | 09:28 PM
ls19integra95's Avatar
as long as you would take it real easy and baby the clutch then it should last for awhile but i would get that changed asap because it could cause other damage if you let it go and it gets worse...
Old Jun 12, 2007 | 10:38 PM
Default Re: (ls19integra95)
what will make a clutch give out quick, its supposed to be a stage 3 competition clutch but i dont think i got what i payed for
Old Jun 13, 2007 | 04:07 AM
Dogginator's Avatar
Daisy... Daisy...
How does this clutch respond when starting? Does it slip alot then? Is there any fluid (oil) leaking in the clutch area?
Old Jun 13, 2007 | 11:20 AM
Default Re: (Dogginator)
it slips at low rpms but it is good at high rpms
HondaLuv3r4Life
Honda Civic (2006 - 2015)
Jan 24, 2019 08:24 PM
danno33
Jul 14, 2009 07:45 AM
ivanson
Mar 16, 2005 11:03 PM
Brett
Feb 12, 2003 04:26 PM
civicracer1993
Mar 10, 2002 10:23 PM
