GS/RS/LS differences from other trims
you've been here for a long time...
Why didnt you search? this has been covered tonss of times.
the RS is the lightest, no power options(I believe).
I dont think it has ABS either.
They all have a nonvtec engine.
the reason the RS is lighter is because it doesnt have any power options or a sunroof.
thx but you think?? u dont drive an integra do you?
I did search but as YOU KNOW you can't type any words with less than 2 letters.
I have known that the RS is the lightest (because of no sunroof) but my main question is if it has ABS or not. I have never seen one, it'd be weird to have an acura with no power windows/mirrors...
found from searching... also found from searching that it does not have abs.
A link to team integra provided this information...
Trim Levels
RS: Regular Series. Available in both coupe and sedan. No sedan available in 1998. Model dropped in 1999. Equipped with the B18B1 DOHC engine putting out 142 HP and 127 ft-lbs. of torque. In 1997, power ratings dropped to 140HP and 124 ft-lbs. of torque. As always, the stripped down model. Standard features were a cassette player, rear window defroster, and tilt steering wheel. Cassette player replaced with CD player in 1997.
LS: Luxury Series. Available in both coupe and sedan. From the RS, the LS adds air conditioning, power windows and door locks, cruise control, and a moonroof. In 1998, the LS became equipped with alloy wheels and in 2000 was given a leather wrapped steering wheel and shift ****. The LS is most popular non-VTEC model Integra and arguably best value.
SE: Special Edition. Available in both coupe and sedan starting from 1995. SE's are only found in 1995 and 1996 model years until they were changed to be named the GS in 1997. From the LS, it added leather seats, alloy wheels on all years, and a rear wing spoiler.
GS: Grand Series. Available in both coupe and sedan starting from 1997. Same standard features as the SE.
GS-R: Grand Series Racing. Available in both coupe and sedan. Equipped with the B18C1 DOHC VTEC engine outputting 170HP and 128 ft-lbs. of torque. Same standard features as the GS minus the leather seats. However, leather seats ended up becoming a standard feature on the GS-R starting in 1999. Again, no auto transmission available for this car.
Type R: Type Racing. Available in coupe only starting from 1997. Not available in the U.S. in 1999. Equipped with fully tuned B18C5 DOHC VTEC engine outputting 195HP and 130 ft-lbs. of torque. Check the Type R Special for the technical differences on this car. Standard features were exclusive of the rest of the models and in 1997, included black mesh/suede bolstered seats with red stitching, mid-height rear wing, front lip spoiler, body colored side rocker panels, shaved door moldings, leather wrapped steering wheel and shift ****, power windows and door locks, and exclusive white powder-coated light-weight alloy wheels with 5-lug configuration. In 2000, added standard features were an aluminum shift ****, gunmetal lightweight alloy wheels, and air conditioning. As with the GS-R, no automatic transmission was available for the Type R. But if you were thinking about getting this car with an automatic transmission you shouldn't be thinking about this car at all.
Trim Levels
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numbnuts22715 »</TD></TR><TR><TD CLASS="quote">found from searching... also found from searching that it does not have abs.
Trim Levels
RS: Regular Series. Available in both coupe and sedan. No sedan available in 1998. Model dropped in 1999. Equipped with the B18B1 DOHC engine putting out 142 HP and 127 ft-lbs. of torque. In 1997, power ratings dropped to 140HP and 124 ft-lbs. of torque. As always, the stripped down model. Standard features were a cassette player, rear window defroster, and tilt steering wheel. Cassette player replaced with CD player in 1997.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FalkenSiR »</TD></TR><TR><TD CLASS="quote">coo thx but does the RS have ABS and power windows/mirrors?</TD></TR></TABLE>
learn to REED!
Trim Levels
learn to REED!
loquito
Nov 30, 2005 01:11 PM
Grip
Oct 21, 2004 02:49 PM
