spring question
Old Jun 12, 2007 | 02:47 PM
r1ch1e's Avatar
Default spring question
i was wondering if there are a little stiffer springs for stock ride height?
Old Jun 12, 2007 | 05:26 PM
integra racr04's Avatar
Default Re: spring question (r1ch1e)
Old Jun 12, 2007 | 05:41 PM
alexisthemovie's Avatar
just get adjustable shocks
Old Jun 12, 2007 | 07:05 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: (alexisthemovie)
I'm sure you can find them somewhere. But why dont you get ground control or similar coilovers, and run them at stock height? I think the highest setting on Ground Controls sets you up at .5'' lower than stock. Thats not much.
Why do you want to do this? Someone said to get adjustable shocks....but that wont cure body roll and loading on sweeping corners. Only on autocross style sharp turns.
Old Jun 12, 2007 | 08:46 PM
well if i wanted to cure body roll, i would just go with a stiffer (itr) rear sway bar.
Old Jun 12, 2007 | 09:22 PM
ForceFed Motorsports's Avatar
Do you even PLEBE R8?
Get a set of eibach springs, there a little stiffer than stock and pretty much the same ride height
Old Jun 13, 2007 | 05:02 AM
r1ch1e's Avatar
Default Re: spring question (ForceFed_Motorsports)
i want to keep stock height because i drive into charlestown in mass and if anyone from the boston area will know what i'm talking about. i have my itr sways with asr brace. and to complete it i was thinking of the gr2 with stock springs. what do you think of that setup?
Old Jun 13, 2007 | 06:55 AM
The eibach springs are seriously not much difference in ride height but will at least be a little stiffer. I wouldnt worry about rough roads with them lol. You'll still be a foot off the ground.
Old Jun 13, 2007 | 06:57 AM
Libertariat's Avatar
Ek Forever y0!
Tein s. techs and your choice of shocks
ITR rear, gsr front sway.
body roll problem solved.
Old Jun 13, 2007 | 11:21 AM
B serious's Avatar
Default Re: spring question (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">Tein s. techs and your choice of shocks
body roll problem solved.</TD></TR></TABLE>
Tein S techs drop DC2s 2.6''f and 1.7''r . I'd say thats a LOT lower than stock. Those springs are also not stiff enough to keep you off bumpstops on really hard bumps and turns with sticky tires. Try some ITR springs maybe.
Modified by B serious at 1:38 PM 6/13/2007
Old Jun 13, 2007 | 02:01 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r1ch1e &raquo;</TD></TR><TR><TD CLASS="quote">i want to keep stock height because i drive into charlestown in mass and if anyone from the boston area will know what i'm talking about. i have my itr sways with asr brace. and to complete it i was thinking of the gr2 with stock springs. what do you think of that setup?</TD></TR></TABLE>
An ITR sway bar with stock springs could be asking for trouble. Since you have the ASR brace, you could end up putting alot more stress on the sway bar end links than they were designed for.
I would say just pick up stock ITR springs and maybe some mildly stiffer aftermarket shocks like Tokico HP's, or perhaps a complete ITR suspension w/ factory ITR shocks (would require rear LCA's also).
Old Jun 13, 2007 | 04:30 PM
the kyb gr2 wont make a difference. i would say kyb agx at the very least if you want it to be stiffer (with adjustability) and pair them up with tein h tech.
Old Jun 13, 2007 | 04:39 PM
r1ch1e's Avatar
dam. i just ordered the gr2's. so it's a bad idea gr2 with itr and asr with stock springs?
Old Jun 13, 2007 | 05:41 PM
dukeofurl187's Avatar
+1 a rear sway bar will do the trick....if i were you i would invest in this mod for sure......
Old Jun 13, 2007 | 08:44 PM
Community Builder
Default Re: (r1ch1e)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r1ch1e &raquo;</TD></TR><TR><TD CLASS="quote">dam. i just ordered the gr2's. so it's a bad idea gr2 with itr and asr with stock springs?</TD></TR></TABLE>
A large rear sway bar with stock springs is going to make the sway bar have to work alot harder and put more strain on it, and the end links. You might check in the suspension forum but I'm pretty sure they would recommend having something stiffer than stock springs to pair with the ITR rear sway bar.
Old Jun 13, 2007 | 09:19 PM
gr2 are only good with stock shocks. they are seriously really shitty.
i ran them with relatively soft megan racing springs (280f, 230r) on my first dc4 integra because i thought i could go cheap on shocks.
of course that was before i knew any better.
just say you meant to order agx instead.
Old Jun 14, 2007 | 12:12 PM
r1ch1e's Avatar
agx with stock spring? i'm just looking to get a little stiffer. but at ride height because this is my dd and i'm not going to race on it. just spirited turns and hugging rotarys sometime.
Old Jun 14, 2007 | 12:22 PM
Community Builder
something like OEM Type R springs would probably be your best bet if you can find a set.
ady2glude707
Suspension & Brakes
Jan 20, 2012 08:01 PM
katoeh2o
Suspension & Brakes
Mar 29, 2011 08:03 AM
homemadeturbo
Suspension & Brakes
11
Jan 25, 2008 07:49 PM
YodaIsGod
Dec 20, 2001 04:59 PM
arete213
Oct 3, 2001 03:39 AM
