Bogging problem.
Old Jun 9, 2007 | 05:00 PM
Insomniac_racer's Avatar
Default Bogging problem.
I have a 95 Teg with a B18b1 motor in it with some minor mods. 70mm TB, Greddy header/full exhaust system, Injen Short ram intake, b16 pistons etc.
I recently did a valve adjustment on my car and soon after doing so I noticed that when I hit the gas between 2-4.5k rpm that it would almost cut out or bog on me. I could feel a total lack of power which wasn't like that prior to doing the Valve adjustment.
When I worked on the valves I noticed that my sparkplug wires were almost like glued into the holes that connects into the plugs and I had to pull preatty hard to remove them.
I was wondering in doing so that maybe I damaged the plugs causeing me to not get enough spark? I am also smelling alot of fuel when I am driving around town (I.E Start stop kind of driving.)
If anyone has any ideas of what this may be please let me know. Thanks =D
Old Jun 10, 2007 | 10:12 AM
Default Re: Bogging problem. (Insomniac_racer)
Bump any help would be great I am burning up gas at a rapid rate.
Old Jun 10, 2007 | 10:36 AM
Vtec_Dude's Avatar
did you put the spark plug wires back in correctly? or did you adjust the valves right? I had the same problem when i did that on my old teg. Couldn't figure out what it was, so I just did everything over again carefully and it fixed everything.
Old Jun 11, 2007 | 08:18 PM
SsB_Db8's Avatar
replace o2 sensor and spark plugs to save gas and reset the ecu
dynamitezz
Oct 28, 2006 08:07 PM
JDM_ITR
Jul 3, 2003 09:20 AM
JDM_ITR
Jul 2, 2003 08:16 AM
