Stuck in Neutral
Well yesterday i was at a light, and i try to put it in first gear. It locked and i tried to put in other gears. It wouldn’t go into any other gear, so i kinda forced it into first and started shifting smoothly. I kinda notice everytime i restart the car again, it get more difficult. Anyone have a clue?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Byaaah! »</TD></TR><TR><TD CLASS="quote">Have you checked your MTF level???</TD></TR></TABLE>
This is what i would do first and foremost.
If your clutch feels soft when, try pump it a couple times, and if it tightens up and goes back into gear then your tranny fluid is low, like the other guys said. Fill it up, check flex line and stuff like that for a leak.
Check To see if ur clutch line/ master cylinder/ slave cylinder is leaking. Check ur clutch fluid reservoir and try rebleeding the clutch, this should solve your problem. also, will the car go into gear fine when the car is off? Or will it not go into gear at all?
jwshilli
Jul 14, 2009 03:02 PM
allmotor.net
May 23, 2004 08:53 PM
