HELP.. AUTOMATIC TRANNY ISSUES
Old Nov 18, 2007 | 11:04 AM
DisOnesAPlaya's Avatar
Default HELP.. AUTOMATIC TRANNY ISSUES
Do anyone know why when i park my car sometime i can get out of park to drive. unless i unlock the saftey switch with the key then go to nuteral and start the car up. and when i park the car i cant get my key out.. the light on the gauge cluster incated that im still in drive "D" but im really in park. i would have to turn off and on a couple of time until the light on come to Park "P" then i will be able to removed my time.. PLEASE HELP.. THANK YOU
Old Nov 18, 2007 | 01:11 PM
blkb18's Avatar
Default Re: HELP.. AUTOMATIC TRANNY ISSUES (DisOnesAPlaya)
Sounds like neutral safety switch issue. Maybe the switch is going bad, or could be a problem with the wireing.
Old Nov 18, 2007 | 02:24 PM
where is that located? under the steerling wheel or is it by the shift boot...
Old Nov 18, 2007 | 03:02 PM
blkb18's Avatar
Default Re: (DisOnesAPlaya)
Every one I have ever seen is on the trans. The shifter cable should attatch to it. Look at your trans while someone shifts it from gear to gear, look for the moving part, that should be it.
Old Nov 18, 2007 | 03:44 PM
HONDRETTI's Avatar
Default Re: (blkb18)
its a piece down in the shifter thats needs to be replaced...
go to g2ic.com and search the forums, theres a write-up and diagram to help you out...
h23vtec_dc2
Oct 29, 2010 11:17 AM
joshblaze101
Transmission & Drivetrain
Jul 30, 2010 10:07 PM
theharlequin
Feb 11, 2008 01:22 PM
juice2929
Jul 27, 2007 07:39 PM
R6E6I6D
Dec 26, 2005 04:38 PM
