Ignition issue? please help
Old Nov 14, 2007 | 12:26 PM
VLP's Avatar
VLP
Default Ignition issue? please help
I was heading home the other day on the high way doin about 100 and my rpms dropped to 0 and my car wouldn't start back up. i have had problems with the main relay, but i don't think it would cause this. There is no spark at all.
any suggestions on what to look for. no sputtering just 0.
thanks vince
Old Nov 14, 2007 | 12:52 PM
bigkvn77's Avatar
Default Re: Ignition issue? please help (VLP)
If the car starts up later like after it has cooled down. It's most likely the coil going bad inside of the dizzy. The main relay controls both the fuel and the spark. So, that may be the cause also. Try jumping the ignition side of the relay and giving it a wirl if it starts right up then it might be the relay. But im guessing its the coil in the dizzy.
Old Nov 14, 2007 | 12:58 PM
WhiteGSR95's Avatar
Default Re: Ignition issue? please help (bigkvn77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VLP &raquo;</TD></TR><TR><TD CLASS="quote">I was heading home the other day on the high way doin about 100 and my rpms dropped to 0 and my car wouldn't start back up. i have had problems with the main relay, but i don't think it would cause this. There is no spark at all.
thanks vince</TD></TR></TABLE>
lol first of all slow down.
but im pretty sure the previous poster is right. when mine went out it did the same thing. some times it would fliker from my actual rpm to zero. check you ignition module
Old Nov 14, 2007 | 03:06 PM
VLP's Avatar
VLP
hey thanks ill give it a try and let ya know
Blazinmiller
Mar 12, 2024 10:32 PM
glpalmer
Jul 13, 2015 06:50 AM
boostmyda
Jun 2, 2010 07:08 PM
livelife46290
Aug 26, 2004 07:07 PM
MrFast4Ward
May 18, 2004 12:35 PM
