o2 sensor
Old Nov 18, 2007 | 01:13 PM
dohc_profile's Avatar
Default o2 sensor
ok so im grabbin a new sensor, most likely denso. neways. theres diff part numbers for b18b1 and b18a1. i see that all gens of dseries share the same plug as the a1, but not b1. does this mean the plugs are not seperated by on board diagnostics? wut the difference?
Old Nov 18, 2007 | 01:21 PM
blkb18's Avatar
Default Re: o2 sensor (dohc_profile)
I dont know what you mean by "separated by obd" but as long as the sensor has the same number of wires it will work. If the connectors are different then swap them. You can even get a univeral o2 sensor for cheaper, which doesent come with the plug and you will have to install your plug on it.
Old Nov 18, 2007 | 03:18 PM
95 integra's Avatar
Default Re: o2 sensor (blkb18)
As I recall the B18A uses a single wire O2 sensor and the B18B1 uses the "normal" 4 wire.
DALE-EK4
40
May 3, 2007 11:41 AM
novtecnoboost
Feb 11, 2007 06:56 PM
EJ8chu
Jan 20, 2007 12:53 PM
so simple
Nov 24, 2004 10:54 AM
